11-20-2018 04:07 PM
Hi
I have tried for a long time to make a wifi access point on my C100 MK and control the camera from my IPad - but no luck. I have tried YouTube tutorials - I have followed the user manual and my IPad is able to find the WIFI hotspot vreated from the camera, but I get the message "no internet conection" - have you made this setup work and any suggestions what might be wrong?
Thanks and greetings.
11-23-2018 04:42 PM - edited 11-23-2018 05:59 PM
Hello gs-dk,
You've set up the bulk of it, but for the sake of ease I have written a set up set up instructions starting from setting up a new Camera Access Point in the menu.
01. Camera Access Point
02. SSID
- Canon1 [Can be edited later]
03. Select the wireless connection mode
- 2.4 GHz
04. Channel 1/11
- 1ch
05. Select the authentication method
- Open/ No encryption
06. Select the IP address assignment method
- Manual
07. IP Address
- 10.0.0.10 > SET
08. Subnet Mask
- 0.0.0.0 > SET
09. Default Gateway
-255.255.255.0 > SET [255 is one click down from 0]
10. The next screen will have you scroll through and confirm the settings, you must press SET on this screen to proceed.
11. Select the network configuration number [1-5]
- Select 1 [You can input a name or leave it 1]
12. Save the network configuration
- OK or Cancel, press SET to OK.
13. Check inside the Network Settings> Remote Settings
- Port should be set to 00080 > SET
14. Confirm or Input camera ID
15. Next, on the camera back out from Network Settings to Other Functions and find Browser Remote. Turn this on to enable control.
16. Next, open the Settings application on your tablet and go into WiFi. Find the camera network, Canon1 and join this network.
17. Next, go into your browser on the tablet- type 10.0.0.10 into the address bar directly and go to it. It should open up Browser Remote on your tablet now.
11-23-2018 06:16 PM - edited 11-23-2018 07:42 PM
Hi Tim
You DID it! It works....
The missing link was no 13 -
Great support - that's one more reason to be a loyal CANON customer.
All the best.
Greetings
Gert
04-25-2019 11:59 AM
forgot to mention I am trying to set up 3 C100 Mark IIs to the same wifi. It seems to me that i may need 3 seperate IP adresses
08-02-2021 02:13 PM
Hi Tim
I went to "New Connection" but it's grayed out. Any ideas?
Ted
08-03-2021 01:55 AM
Hi tedfrank20,
Do you already have a connection with another Wi-Fi network? If so, are you able to select the edit option?
It might also help to disconnect any accessories or connections to a computer, as a test to see if you can isolate the issue.
Beyond that, you may wish to go into the menu, navigate to the wrench icon and then select RESET to restore the camera to default settings. Then you could try setting up a new Wi-Fi connection.
08-03-2021 09:40 AM
thanks Nick. I'll suss it out
03-18-2024 03:47 AM
Thank for the info for all. It is working great. I will use this feature all the time from now on.
