NEW Canon USA EOS Webcam Utility – Mac Official Support/FAQ
by Community Manager on ‎11-11-2020 02:47 PM
*Verified Q&A comments that are commented below this artcile will be given a "kudos" from the official Canon U.S.A. account and added to the FAQ list below.*
Q: What are the supported Canon camera models for the official version?
A: In total there are 43 models -- refer to canon.us/livestream for the full list.
Q: What is the distribution for official version?
A: The beta version was only available in the USA. However the official version will be widely distributed in regions outside the USA. Please check the website of each country or region to see if it is distributed in your area, or contact your local service location.
Q: I want to use the software with high image quality. (I want to use FHD).
A: The resolution using the software is generally 1024x576 when set to video mode.  Please note that this may vary depending on your camera model.
Q: Does continuous use of the camera generate heat?
A: When you don't use in-camera recording, the webcam functionality does not generate more heat than during normal shooting. But, if you use in-camera recording, it will generate the same amount of heat as during normal in-camera recording.
Q: Can I use the camera’s microphone?
A: No, EOS Webcam Utility software doesn't transmit audio through USB connection.Please use your computer’s built-in microphone or an external microphone separately connected to your computer.
Q: What are the supported Mac Operating Systems?
A: Please refer to the below/attached image OR visit canon.us/livestream for the full list of supported Mac Operating Systems.*
*EOS Webcam Utility software does not support apps downloaded from the App Store. Please download the application from the service provider’s website where available.*
Q: What is the frame rate of the video stream?
A: The frame rate depends on the camera model, camera settings, laptop performance and the transmission speed specifications of your laptop and USB, etc., however in most cases it is up to 30 fps.
Q: Can multiple cameras be used with the EOS Webcam Utility software?
A: The software does not support streaming from multiple cameras simultaneously.
Q: How can I increase the output resolution on a USB Feed?
A: The resolution of the video stream through the USB feed cannot be changed. If you need a higher resolution output please consider utilizing HDMI options offered by your camera model, if compatible. Please refer to canon.us/livestream for information on clean HDMI output supported cameras offered by Canon.
Q: Does the EOS Webcam Utility Tool support 4K?
A: The software does not support 4K. If you need a higher resolution output please consider utilizing HDMI options offered by your camera model, if compatible. Please refer to canon.us/livestream for information on clean HDMI output supported cameras offered by Canon.
Q: How long can I stream using the EOS Webcam Utility software? Is streaming limited to 30 minutes?
A: The streaming is not limited to 30 minutes and you can stream until the battery runs out. If you want longer usage please consider an AC adapter and DC coupler as an option. Depending on the camera temprature, camera will automatically shutdown to protect camera device. To prevent overheating it is recommended to set the video resolution to 1080p.
Q: How can I sync the video and audio, or reduce the lag between video and audio?
A: EOS Webcam Utility does not control the sync of video and audio.
Q:Why do I get the EOS Webcam Utility logo in reverse on my video feed?
A:If the previewed image (EOS Webcam Utility logo) on the video feed is mirrored, it will depend on the video conference or streaming application you are using.
Q: What if my camera isn't listed but I tried it and it works?
A: The list of supported cameras includes the cameras that have been tested with the software. We cannot guarantee functionality of the software with a camera not included on the list.
Q: Can the software work via HDMI connection?
A: EOS Webcam Utility software does not support HDMI connection and only supports USB connection. Please check our website for cameras that support clean HDMI output and how to use them.
Q: Why do I see black border in my video feed?
A: When the camera is set to "Still Photo" shooting mode, black side pillars may appear to the border around the video source image. We suggest that you set the camera to "Movie" recording mode. Note: Some selected cameras may still display black side pillars bordering around the video source image, even if set to "Movie" recording mode.
Q: Is it possible to internally record video while streaming?
A: Yes, recording while streaming is supported.
Q: Is there are an internal record time limit while streaming?
A: Recording time while streaming and recording is limited to the cameras video recording time specification.
FIND THE RIGHT WEBCAM STARTER KIT
Whether connecting with colleagues, academic peers, or family and friends, find the right webcam starter kit that works for you.
Comments
on ‎02-10-2021 10:22 AM
My T6i on Mac Catalina 10.15.7 is not detected by any video conference or streaming applications but EOS Utility
I was working fine before I had to do a clean Mac OS installed.
The thing is that the camera works fine with EOS utility capture, but it is not detected by any other video app such as Zoom and OBS.
Looking for someone that could help!
by Product Expert
on ‎02-10-2021 06:14 PM
Hello augerp,
There are a couple of things to try. The first is to restart your computer. The EOS Webcam Utility needs a computer restart in order to work. Make sure you are selecting the Restart option by clicking on the Apple icon in the top left of your screen rather than using the power button on the computer.
The other thing is to make sure your EOS Utility is fully closed before starting your webcam software. When the EOS Utility and the webcam utility are both on at the same time it prevents the webcam utility from detecting your camera. That is because when they're both open at the same time they both try to use the camera at the same time. When closing the EOS Utility make sure to select Quit from the top menu rather than just closing the window. That way it isn't running in the background.
One more thing to do is to make sure your camera is set to Movie mode. Sometimes if the camera is still in photography mode it can cause connection issues.
‎02-10-2021 10:01 PM - edited ‎02-11-2021 09:10 PM
No success yet with your advices.
What I did :
  1. Uninstalled EOS Utility 3.13.10 for macOS
  2. Uninstalled OBS 26.1.2.
  3. Reboot the computer
  4. Installed EOS Utility 3.13.10 for macOS Catalina 10.15.7
  5. Shutdown the computer
  6. Restart
  7. Tested EOS Utility 3.13.10 with my Canon T6i.  = Works just fine!
  8. Quit EOS Utility
  9. Installed OBS 26.1.2.
  10. Made sure EOS Utility was not running and started OBS with the t6i set on Movie Mode = EOS Utility / Canon T6i not detected
Really don't why it is working in the EOS application and not in other apps.
Reinstalled MAC OS Catalina 10.15.7
Still not working
I'm going to downgrade to previous Catalina version
Any thoughts?
Fully reinstalled MAC OS Catalina from scratch - Erased the entire disk and only installed EOS unitlity and OBS.
My T6i camera is detected in EOS utility and I can take pictures from my computer, but the Camera is not detected by any other applications.
I seriouslly need some assistance, since I need to produce some material real soon.
Anyone can help?
Thanks
by Diego Barra
on ‎02-25-2021 07:57 AM
Hi, using webcam utility with Powershot G7MIII and it works fine. I need to record internally in camera while using webcam, how can I do this. Thanks
by Product Expert
on ‎02-25-2021 06:07 PM
Hi Diego Barra,
There is not a way to record internally on the camera while also using the EOS Webcam Utility. We appreciate feedback on features customers would like to see added to our software and cameras. We have a team that documents and handles customer feedback. I have already alerted them to this email, but if you want to contact them directly in the future they can be reached by going to our website HERE and selecting Feedback in the top left corner of the site. We do take customer suggestions and feedback into consideration when we are updating our products and processes.
by Ernesto Peralta
on ‎03-03-2021 01:23 PM
me aparece una imagen de usb y una tacha X , como lo arreglo ?
by Nick Schifrin
on ‎03-17-2021 05:57 PM
Using EOS-R, Mac OS Big Sur, and Zoom and Skype.
I tried everything. Could not get this to work. And then I saw a very strange fix:
Turn off Dropbox / Google Drive / OneDrive.
And viola. It worked. I didn't even need to restart.
by Kash G
on ‎03-20-2021 03:09 AM
I try to connect my EOS 600D as my webcam and its not working. Do you know which is the correct drive to use?
‎03-26-2021 03:30 PM - edited ‎03-26-2021 03:54 PM
Just another data point for anyone in the same situation as me.
  • macOS Big Sur (11.2.3)
  • Zoom (5.5.5)
  • Canon 70D
  • EOS Webcam Utility 1.0 (listed for Catalina in Downloads)
This works, most of the time. When its working, and I've been using the camera for longer than 20-30 mins, the shutter breifly closes and reopens. So the video goes black for 1-2 seconds. That's not a dealbreaker for me and I suspect its related to a hardware limit in the camera (I've heard this has to do with tax classification as not a video camera). Starting up can be a little slow, and if I press the shutter button (like I'm trying to take a picture) that tends to wake it up quicker on the initial startup.
Sometimes though, it just doesn't work. I turn the camera off and on, press the shutter button, unplug and replug the cable. Nothing that I'm doing intentionally brings it up. I just tried closing a piece of software that I'm running (Kap) and trying again, and it worked! But then i tried reopening Kap to see if that is specifically the culprit, and its still working. So that's very unconclusive and not satisfying.
Also hoping for official Big Sur support soon!
powered by Lithium
