01-23-2021 12:06 AM
So running Windows 10 (64bit)... and OBS Studio 26.1.1. I have a Canon EOS Rebel T6. I've dowloaded the Utility as directed for my laptop, installed as directed, etc. Opened up OBS and get the "EOS Webcam Utility (Red 'X' with connection cable)" on the black screen. I originally tried a HDMI cable out of the T6 > into a USB3.0 to HDMI Converter > into three differnt USB ports with no visuals. Any help would be greatly appreciated.
01-23-2021 02:21 PM
@ErikSanchez wrote:Unfortunately, that doesn't work either. So, it's either the camera itself or the cable(s) I've tried... maybe?
If the regular EOS Utlity does not work, then you have a cable problem. Make sure you have a USB data cable, not a cheap charging only cable.
01-23-2021 02:33 AM - edited 01-23-2021 02:33 AM
Does the regular EOS Utility work for you? Can you connect to the camera and perform Remove Shooting and downloads?
01-23-2021 10:47 AM
01-23-2021 02:21 PM
01-24-2021 01:43 PM
Thank you... I will try that
01-24-2021 06:55 PM
Waddizzle, thank you! Got a new cable and it worked!
05-11-2021 03:14 PM
I've been using EOS Webcam Utility just fine with my Canon Ti3 Rebel and USB cable. I thought upgrading to an hdmi mini to hdmi cable would improve quality but the software doesn't recognize it. Is this simply related to my Dell XPS laptop or am I stuck with using the USB cable?
05-11-2021 07:59 PM
@shareski wrote:I've been using EOS Webcam Utility just fine with my Canon Ti3 Rebel and USB cable. I thought upgrading to an hdmi mini to hdmi cable would improve quality but the software doesn't recognize it. Is this simply related to my Dell XPS laptop or am I stuck with using the USB cable?
You should only use the USB cable.
03-24-2021 06:54 PM
I added tried a new cable and still could not connect. I still have Red 'X' issue.
