03-19-2023 08:00 PM - edited 03-19-2023 08:01 PM
Been trying to master the new Lenovo laptop which has W11. I found the Adobe PSE 2021 download. So I downloaded it. Everything looks OK so far. On W10, the photos on File Explorer were separated as XXXX.CR2 and XXXX.jpg photos. Now when I click on file and click on Open in Camera RAW, I select the file and the photos are side by side with IMG and the number. However, when I click on a photo, there is no difference until it is loaded into PSE. Then the XXXX.CR2 shows up at the top of the photo. The two photos are identical and are "sorted" with CR2 on the left and the jpg is on the right. Any way to separate them with the CR2 and jpg on the appropriate photo? These are existing photos. Thanks.
(Still trying to figure out to download them from the memory card to a designated file.)
03-19-2023 09:01 PM
Open File Explorer (Windows key +E), go into "View" and enable file extensions... See attachment.
Newton
03-19-2023 09:01 PM
Newton
03-20-2023 08:51 AM - edited 03-20-2023 09:02 AM
Thanks. Will give it a try. Will copy screen to substitute for my senior memory.
03-20-2023 09:03 AM
Newton, that did it! Many thanks. Might have more questions re: Canon T7 and downloading. This might have another "cure" for me.
