09-11-2021 10:36 AM
Been playing around with PSE on Quick edit. I needed to delete some things in a photo so I got into the PSE for Dummies and went to guided edit. Played around with this and actually deleted some things in the photo. Will try to attach a before and after photo for your critique. I'm sure that there might be some things I can do further to enhance the edited photo. Also figured out how to take an edited RAW photo and convert to JPEG.
Thanks to all for your help!
09-11-2021 11:30 AM
Check out this YouTube channel, Photoshop Training Channel. It is geared towards full blown PS, though.
https://youtube.com/c/Photoshoptrainingchannel
09-11-2021 11:49 AM
Been looking at it but it's hard to follow them to see what they're clilcking on. Print is very tiny. Have to go back and "rewind."
09-11-2021 02:14 PM
BTW, it was one of the videos plus the book that gave me direction to edit the original photo.
09-11-2021 06:59 PM
If you are using PSE look into the software called Elements+
09-12-2021 10:24 AM
I like the Adobe Photoshop Classroom in a book for PhotoShop Elements 2021 by Jeff Carlson.
It comes with example photos to work with.
09-12-2021 11:20 AM
@Tintype_18 wrote:Been playing around with PSE on Quick edit. I needed to delete some things in a photo so I got into the PSE for Dummies and went to guided edit. Played around with this and actually deleted some things in the photo. Will try to attach a before and after photo for your critique. I'm sure that there might be some things I can do further to enhance the edited photo. Also figured out how to take an edited RAW photo and convert to JPEG.
Pretty good work. Kudos.
When I do this type of stuff, I do it on a duplicate layer, and use a layer mask. Putting it on a separate layer allows me the flexibility to control the exposure of the re-sampled images that I use to hide/remove stufffrom the original shot.
09-13-2021 08:24 AM
Waddizzle, thanks. Felt good about my first edit. Sending them off today and letting the editor pick.
I have PS Elements 2021 and the book on it by Barbara Obermeier and Ted Padova.
John
09-14-2021 05:39 PM
Correction- I used Guided Edit for this editing session. Quick Edit, as you all know, is very limited in scope. So much to learn!
