EOS VR Plugin Not Appearing in Adobe Premiere Pro After Installation on Windows 11
chris_m52
I downloaded the vpw-1-6-0-5-10l.zip file and ran the .exe installer for the Canon EOS VR Plugin on my Windows 11 machine. The installation completed successfully without any errors.
I am using the Canon EOS R5 C Camera with the RF5.2mm F2.8 L Dual Fisheye Lens for shooting 180° video. After installing the plugin, I opened Adobe Premiere Pro and attempted to import a few .crm files. However, I cannot find any sign of the EOS VR Plugin in Premiere Pro. I’ve checked the plugin installation path at C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore\EOSVRPluginLib, and the plugin files appear to be present.
Despite the files being installed in the correct location, the plugin is not showing up within Premiere Pro, either in the Effects panel or under Window > Extensions. I’ve seen others report a similar issue online, but I haven’t found a clear solution yet.
Any help would be appreciated. Thanks, Chris
1 REPLY 1
madwiser
Did you restart Premiere after installing the plug-in?
