05-10-2020 08:34 AM
Hello there!
I have followed every instruction found at support section and tried different solution but no avail. My EOS Utility, 2 and or even 3 can not detect my Canon EOS700D. I can see my EOS700D on my computer connected but it seems I can not find solution for my problem. Here are some details;
Using:
Dell Inspiron 15 5000 series 64bit (Windows 10).
05-11-2020 01:57 PM - edited 05-11-2020 02:34 PM
One other thing to try that I saw on line.
Go to Device Manager->Portable Devices and delete the camera.
Then connect camera and turn it on to force the computer to re-find the device.
05-10-2020 11:09 PM
I once posted a link in a forum thread that contined to Microsoft's list of WMP versions, which had links for all of the most current Windows builds. I have not been able to find it. It would be similar to this link.
https://support.microsoft.com/en-us/help/3145500/media-feature-pack-list-for-windows-n-editions
I hope and would want to believe that Windows updates over the past few years have homogenized the differences between Windows versions, but that is only wishful thinking.
If you try to download WMP from Microsoft on the target machine, though, you should be linked to the correct WMP version for the Windows Build number on your PC. .... In theory.
05-11-2020 06:52 AM
I just found out that my windows 10 home has windows media player installed and is working properly.
I tried updating the WMP and re-install eos utility but no avail and fail! Still looking for another way!
05-11-2020 07:08 AM
At this point I think you need to call your in-country Canon support line.
05-11-2020 09:11 AM
05-11-2020 09:27 AM - edited 05-11-2020 09:28 AM
I would say yes.
Do you have any access to a second computer to at least see if the camera is recognised as a disk drive and shows up in the This PC window?
05-11-2020 10:04 AM
05-11-2020 10:10 AM - edited 05-11-2020 10:30 AM
i have W10 Home, so I don't think that"s the problem.
[Mod note - Removed screenshot - your Windows serial number is personal information and can be stolen by hackers.]
Thanks Stephen.
05-11-2020 10:12 AM
05-11-2020 10:27 AM
i don't.
Maybe go through and delete any software you don't truly need for now to see if there is a conflict.
Also, give Canon a call.
The nuclear option is to do a clean reinstall of Windows.
05-11-2020 10:27 AM
