05-10-2020 08:34 AM
Hello there!
I have followed every instruction found at support section and tried different solution but no avail. My EOS Utility, 2 and or even 3 can not detect my Canon EOS700D. I can see my EOS700D on my computer connected but it seems I can not find solution for my problem. Here are some details;
Using:
Dell Inspiron 15 5000 series 64bit (Windows 10).
05-11-2020 01:57 PM - edited 05-11-2020 02:34 PM
One other thing to try that I saw on line.
Go to Device Manager->Portable Devices and delete the camera.
Then connect camera and turn it on to force the computer to re-find the device.
05-10-2020 11:15 AM
05-10-2020 11:45 AM
@seanebue wrote:
I am using Windows 10 Home Single Language Version 1909
OS build 18363.815 and I have multimedia features except windows media player. I think it does not apply with me.
See this:
05-10-2020 11:59 AM
05-10-2020 12:04 PM
05-10-2020 01:30 PM
@seanebue wrote:
I remember last time, I used my eos700d connected to my smartphone android using only the white canon usb cable and a third party app installed on my smartphone, so there is nothing wrong with the cable and as well as the dslr. Im wondering what I am missing from the process of installation.
Perhaps you cable is the issue. I do not see how the same cable that can connect to a smart phone can also be used to connect to a USB port on a Windows PC.
John is correct about needing Windows Media Player, WMP, installed on a Windows 10 PC. Your phone is not running Windows. Be ware that there are different versions of WMP that are available for download.
You must match up the build number of your Windows installation with the version of WMP you are downloading. For example, Windows 10 N and Windows 10 RN have different WMP downloads.
05-11-2020 07:36 AM
By the way, the mini usb data cable for eos 550, 600, 650 are all the same and can be use as well in eos700d?
05-11-2020 07:43 AM - edited 05-11-2020 07:44 AM
Yes. The only difference in cables is some are power only and some are data and power.
05-10-2020 07:37 PM
05-10-2020 07:43 PM
05-10-2020 07:55 PM
