03-23-2022 03:40 PM
I was trying to take photos and save them directly on the network drive (Windows) but got an error "No more shot is available". At the same time, I was able to download photos on the network drive.
If anyone has an answer or any solution would really appreciate it!
Thank you!
03-24-2022 08:43 AM
Hi there,
I wonder if this has anything specific to do with the network drive or network access from EOS Utility. Are you able to set a local drive as the destination and save the images that way or does the same message appear?
03-24-2022 07:14 PM
Does the EOS utility use a URL or does it require a drive to be mapped to a specific point on the network?
04-21-2022 02:32 PM
It does require a specific point on the network, as far as I understand.
04-21-2022 02:22 PM
Thank you for the response! I can select and download photos through EOS Utility v.3 on the network drive (mapped as a local drive). But, if I try to take a photo remotely through the EOS Utility I'm getting "No more shot is available". If I set a local drive as a destination I don't have any problems.
04-21-2022 03:25 PM
I suspect this is a networks security issue from the windows end - this kind of error suggest to me you have a rights denial. You may need to go into the File Manager and set the specific sharing rights for the network folder and the share FOR THAT FOLDER so that they are available to read/write/delete.
