07-17-2019 07:16 PM - edited 07-17-2019 07:22 PM
I had been using EOS Utility 3 successfully for a long time, and I love it!. Today, it crashes on startup( I see the splash screen showing ver3,then itt crahses, see event info below:
Faulting application name: EOS Utility 3.exe, version: 3.10.20.0, time stamp: 0x5c356928
Faulting module name: KERNELBASE.dll, version: 10.0.17134.885, time stamp: 0x59816e73
Exception code: 0xe0434352
I've tried rebooting and re-installing. As far as I can tell, I'm using the latest version. EOS Utility 2 works fine on my older Canon...
Any suggestions?
thanx, mark
Log Name: Application
Source: Application Error
Date: 7/17/2019 7:11:21 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Mark-desktop
Description:
Fault offset: 0x00112cf2
Faulting process id: 0x24c4
Faulting application start time: 0x01d53cf4f1a5e79d
Faulting application path: C:\Program Files (x86)\Canon\EOS Utility\EU3\EOS Utility 3.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 93d17d7e-cf73-486e-bb57-6484ffcb2ef0
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2019-07-17T23:11:21.011822300Z" />
<EventRecordID>22580</EventRecordID>
<Channel>Application</Channel>
<Computer>Mark-desktop</Computer>
<Security />
</System>
<EventData>
<Data>EOS Utility 3.exe</Data>
<Data>3.10.20.0</Data>
<Data>5c356928</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.17134.885</Data>
<Data>59816e73</Data>
<Data>e0434352</Data>
<Data>00112cf2</Data>
<Data>24c4</Data>
<Data>01d53cf4f1a5e79d</Data>
<Data>C:\Program Files (x86)\Canon\EOS Utility\EU3\EOS Utility 3.exe</Data>
<Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data>93d17d7e-cf73-486e-bb57-6484ffcb2ef0</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>Log Name: Application
Event ID: 1000
Level: Error
Keywords: Classic
User: N/A
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>100</Task>
<Security />
</System>
<EventData>
<Data>24c4</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
07-18-2019 10:15 AM - edited 07-19-2019 12:19 AM
Greeitngs,
What version of windows are you using?
Have you recently updated or upgraded the OS?
What AntiVirus are you running?
A few things you can try.
Create and new user profile with admin permissions. Test the utility again and see if the behavior follows?
Run SFC /SCANNOW from a elevated command prompt and check the OS for integrity violations.
07-21-2019 10:47 AM
I'm running the latest Windows 10, it automatically updates from MicroSoft. Running McAffee virus.
Creating another user profile works. So there is something "bad" in my user profile, how do I clean it all out? I tried removing and re-installing to no avail...
thannx for your suggestsions.
mark
12-21-2020 09:47 AM
I'm trying to hook up my SL2 via wifi to my computer via the EOS Utility ( so I can download my images via wifi ).
When I get to the pairing step of the process, my camera does not show up in the "EOS Pairing Software" dialog.
After some searching (mostly on this forum) and looking at Windows10 Application logs, I found the following eosupnpsv.exe fault error. I'm running the latest EOS Utility (the previous version did not work either)
Any suggestions?
