09-18-2024
03:29 AM
08:16 AM
EOS Utility 3 is Terrible
This has got to be one of the worst pieces of software ever. Come on, Canon! Why can't you get this right? Why is this so difficult for you? Why do I keep getting this error message every time I try to connect my R6 to my M1 MacBook Pro using EOS Utility 3? It is so frustrating!
09-18-2024 09:10 AM
Have you tried doing this when your MacBook is plugged in and not less than 20% battery?
When the power is critical, macOS likes to be stingy with where it allocates power, and USB is often one of the first things it cuts. Another issue that could be preventing your camera from connecting is the type of cable you're using. Believe it or not, there are several kinds of USB C cables that don't all do the same things. Some are power only, others transfer data very slowly, some are "normal," and others are Thunderbolt-rated. You don't need a Thunderbolt-rated cable, but you need a decent one that transfers data and power.
If you have tried a different, quality cable, and your MacBook is plugged in, and you're still having problems, give our team a call so they can troubleshoot with you. Support is at 800-OK-CANON (800-652-2666), Monday through Friday.
12-23-2024 10:59 AM
What USB-c cable is recommended? Is there a reasonably priced one on Amazon? The cables on that canon sells are way overpriced. Thanks.
12-03-2025 09:26 PM - edited 12-03-2025 09:28 PM
I’ve had the same issues for a while now. I made a complaint with canon and was just fed generic useless emails and nothing worked. They won’t accept their software is buggy and doesn’t work Properly, instead they try blaming the user and default to gaslighting. I’ve been back and forth countless times and I’m finally done with them. I’ll be getting rid of my kit and I’ll never use these again. Shame really as they were my favourite for over 27 years.
I’ve just had enough. Great cameras but they are Totally inept when it comes to this software.
12-03-2025 09:31 PM
You need software that actually works properly lol.
Google this issue and there are 100s reporting the same thing. YouTube, websites, forums etc. unfortunately canon won’t admit there is anything wrong.. strange eh?
12-04-2025 08:58 AM
Is accessory connection configured properly?
Do you have any background apps running that might gather photos, like Drop Box?
Does your camera show up when you select Image Capture?
