08-06-2024
09:14 AM
09:21 AM
Took Rebel T3 out of closet after 8 years
yes it's been a while since I used regularly. Grandfather now and just shoot family and vacation photos. Camera worked like a charm, great photos. Cut to the chase. New computer so I installed CD's that came with camera and registered, must not have done when first purchased. Having issue downloading images. Went through utility and put in preferences, while camera was connected. Didn't work. Downloaded using "Photos" app and have photos where I want them. What did I do wrong and how to correct. Running Windows11 but canon site says it detected windows10.Need someone to point me in right direction. Appreciate any suggestions I am a novice with camera and computer.
08-06-2024 09:30 AM
Why do you want to use the Utility if Photos works fine?
Are we talking about 2 different computers here?
08-06-2024 10:55 AM
Did you download the EOSU app from your camera CD and the run the 2.14 updater from the Canon support site for the T3?
The T3 requires EOSU Version 2. Version 3 will not recognize the camera.
Version 2 may not be compatible with W11.
You could try downloading EOSU 3.13.20 from the 1D X Mark III support site. It will install the most recent version of EOSU2. (Note that you need to select W10 as OS version).
08-07-2024 01:18 AM
EOS Utility 2 (and the 2.14 Updater) is most definitely compatible with Windows 11. I have installed it on a number of computers.
