EOS 90D, EOS Utility 3 Failing to Import Direct to OneDrive
adventurousone
I just moved to MacBook Pro, and trying to implement my workflow.
I install EOS Utility 3, latest version, made for my 90D and Macbook Pro running Ventura. When I try to choose my OneDrive, it gives this error of "You do not have access or permission for the folder. Please select a different folder."
I have verified no access or permissions issues. I also included a snip from the closest thing I found online that describes the same issue I'm having. I unfortunately don't have an extra pc to keep for the sole purpose of EOS Utility workaround that this person had to do.
How do I resolve? I need the solution to utilize my macbook pro, and to directly upload to onedrive via EOS utility. How do I do this? Can anyone help?
Image 9-6-23 at 7.03 PM.jpegImage 9-6-23 at 7.03 PM.jpegImage 9-6-23 at 7.06 PM.jpegImage 9-6-23 at 7.06 PM.jpeg
5 REPLIES 5
Does The EOS Utility have full disk access permissions in Mac > Security and Preferences?
I remember a similar issue with Google drive last year in DPP, but do not recall what the solution was. John may remember.  I'll ping him.
Waddizzle
I do not believe there is anything wrong with that behavior.  I do not believe the EOS Utility has ever allowed you to download directly to a network connected drive.
I have always downloaded locally to my computer and later move/copy the files to network storage.  You can download to any drive that is locally connected, like a USB hard drive.
rs-eos
Yes, do check out System Settings | Privacy & Security.  Look at both the "Files and Folders" and "Full Disk Access" section.  "Files and Folders" would give you more granular control if you don't want applications to have access to everything.  e.g., under "Files and Folders", you can grant access to "Removable Volumes" independent of other access.
Ricky
jrhoffman75
I get the same error on my MacBook with Full Disk Access permission. No problem connecting on my PC. I don't recall the DPP issue.
Based on others consensus, modifying the path might not be allowed.
One other thing I can think of trying.  Enable the "Show Library Folder" option. Not sure if this provides any support to edit the path.
Another possibility is image.canon  You must be running the latest version of FW on your 90D.
OneDrive is not listed, but might be supported.
image.canon | Forward images to other cloud storages
Friends and Family
