DPP4 Preferences, View Settings, Default Sort Order
KeithHill
In Preferences, View settings, Default Sort Order, I select anything other than File Name, tick the "Save sort order for each folder" box, click "OK" then restart DPP4 (per the "*Changes take effec after restarting" notification.
The selected sort order only applies to the folder I was in when I selected it in Preferences; other folders default back to "File Name" for sorting.
It seems that ticking the "Save sort order for each folder" has no effect.
Am I doing something wrong, or is this a bug? If a bug, how to I request Canon to fix it?
jrhoffman75
Welcome to the forum.
The DPP manual wording often leaves much to be desired.
I just tried an experiment and here is what I found:
The default setting applies when you start up DPP, but when you select the retain check mark you limit that default setting to the folder you are in when you made the change; other folders are unchanged from the previous setting. This allows you to have different settings for different folders.
If you change the default order and uncheck the box you get a popup asking if you want to change all folders.
2 REPLIES 2
jrhoffman75
AND, that worked! Many thanks. Some kind of inverse logic in operation here, I think!
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
