02-26-2024 02:59 PM
Been using this lens for years and LOVE IT, with both the CANON gelatin UV and Polarizing drop in filters (52mm)...I thought it would be easy to purchase either a solar or ND (6-9 stops) or variable ND drop in lens and get ready for the Eclipse (April 8, 2024)....OH NOT THE CASE:
Canon: we don't make one...3rd party only
3rd party all sorts of ND/VND/Solar lens (52 mm) but all SCREW IN (ie like the front of the lens not the back where the drop in filter is (between bayonet and body)....BTW, canon says the face is a 5inch lens (equals 127mm by my math)
I"ve read numerous astronomy/lens users sites and they describe/show a picture of the drop in filter with a screw in lens...(at the same time down the discussion they alert all that it doesn't work, particularly with the V ND lens as its too thick....some wanted to shave it down to fit...OUCH)...
BTW< there are NO Threads on either gelatin/polarizing drop in filters...The cover does pop open on the gelatin/UV but the glass doesn't come out...
B&H wants to sell me a variable size (105-135 solar filter (for use w/ binoculars and telescopes too)...sounds like a patch night likely to produce high quality photos of the big day....
HELP!! Please include pictures of how you do it... This can't be such a problem as i'm told this is one of the top lens (300-600 mm FL) to use to shoot the eclips
02-29-2024 11:49 PM
BTW, kzzzz40, you might want to check out what I just posted:
03-19-2024 04:02 PM
Canon Explorer of Light, Keith Ladzinski is partnering with the Weather Channel to talk about the upcoming solar eclipse. I thought you all might find this piece interesting.
03-22-2024 11:04 AM - edited 03-22-2024 11:04 AM
