11-28-2022 01:37 PM - last edited on 11-29-2022 09:02 AM by Danny
What is the best lens for Cannon 700D?
11-28-2022 01:48 PM
The one you have with you. 8^)
What do you want to shoot?
What budget?
What lens(s) do you have?
11-28-2022 01:48 PM
For what purpose?
If you just want a general all-around lens with good zoom range check out the Canon EF-S 18-200mm zoom.
11-29-2022 12:01 PM - edited 11-29-2022 06:00 PM
"The one you have with you."
This is always the correct answer. The one(s) you have are always better than to one(s) you wished you had.
However, starting from scratch, ground zero, I have no lenses, what is the best lens. Who knows? For what?
The standard kit lens 18-55mm zoom is the best most general purpose lens. It will do what 80% of what the average person wants. It won't do very well for macro bugs or a Moon shot. The beauty of a DSLR or the new mirrorless cameras is they can use several, many, different lenses. So, what is the best lens? The one(s) you have.
11-29-2022 04:38 PM - edited 11-29-2022 05:43 PM
What lens do you currently have? And what are you currently struggling with? Here are a few questions to help get things started:
Also visit Canon's Lens Buying Guide.
11-29-2022 05:30 PM - edited 11-29-2022 05:56 PM
What are you mainly photographing wildlife, sports, portraits or weddings. This is what ultimately determines what lens(es) you need. Are you running into limitations as @rs-eos has pointed out. Do you have a budget if you decide to get more lenses. If not the standard zoom EF-S 18-55mm lens should cover everything you generally need.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired 8/2007-11/8/2022), EF 50 F/1.8 STM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired 8/2007-5/26/2022) & 5D Mark IV
430EX III-RT & 600EX II-RT
