01-08-2025
09:17 PM
09:21 PM
StevenMOD
Received my first EOS camera to take pictures on upcoming Safari trip. Which memory card should I get? Any other helpful info would be amazing!!! Thank you so much!!!
01-08-2025 09:23 PM - edited 01-08-2025 09:52 PM
amorros,
congratulations on the new camera and upcoming trip.
General advice on SD cards:
Good luck!
LZ
01-08-2025 10:15 PM
It totally depends on the camera you bought. How fast it can record data (data bus).
One thing you can do is look in the advanced users guide for your camera, which can be found on the Canon support web site for your camera. It will recommend the proper memory card(s). One thing's for sure, you want to get as many as you can afford. Don't rely on just one big card (all your eggs in one basket is bad juju). I prefer multiple smaller cards like 32 or 64GB for stills and maybe 128GB for video. Also consider dumping the days shots onto a laptop and even getting an external USB storage device, like the SanDisk 2 or 4TB unit for double protection. Do not use your SD/CF/CFe cards as storage. Redundancy is the plan, especially on the "Trip of a Lifetime"
Personally, I prefer SanDisk brand and have never had a failure in all the years I've been using digital.
Newton
01-15-2025 06:48 PM
My recommendation is to match your card with the highest rating of your camera with your cards. There are some good YouTube videos that explain what the ratings mean and they can be very confusing.
Buying cards that exceed your camera's specs is a waste of money and with underrated cards you could miss a shot due to buffering or ruined video.
Lexar, Sony, ProGrade are excellent cards. I know that SanDisk is having a compatibility recall with some Canon cameras. I would favor Lexar or ProGrade depending on your budget. If you only shoot stills, I'd rather have 4, 64GB cards than one 256. That way if one fails you still have the others. If you shoot a lot of video then you may need to go to a larger card capacity to accommodate larger file sizes. If you are not shooting with dual card slots (w cards recording the same images at the same time) you should replace them often say every 12-18 months. If you are shooting with dual card, make sure they match as a best practice.
01-16-2025 06:02 AM
Good advice from all posters. Typo - should be SDXC.
