02-15-2020 05:58 PM
I built a "camera rig" for use with my DSLR camera that utilizes a single NP-F970 battery to power not only an external 7 inch LCD monitor, but also the DSLR via a "dummy battery" that inserts into the camera's battery compartment that has a length of cable coming out to plug into the NP-F970 battery plate.
The battery is 7.4 volts, 7900 mAh and should - in theory - be able to power my XA-11 camcorder that I now want to use on the camera rig instead of my DSLR - IF there is a way to do it.
Has anyone ever done anything like this, or know of a way to do so??
Thanks for reading!
GEvans
02-15-2020 07:48 PM
GEvans,
I appreciate your interest in making this work. At this time though, we do not have a method to make this work or products we could recommend for this.
02-15-2020 07:48 PM
GEvans,
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
