08-19-2021 03:44 PM
Hi folks,
Sorry to ask a couple of questions all at once.
I picked up a HDMI to USB video intake capture card for the Canon Vixia HF R800.
I was somewhat amazed to see that it actually worked out of the box! I use Ubuntu Linux and it nevertheless captures the camera perfetly into OBS Studio.
The only problem I've seen so far is that I get "auto power off" flashing on the monitor which of course makes it through to the feed. I have that setting configured so that I'll be able to "set and forget" the webcam on a tripod and have it running on mains power.
Is there any way to forcibly disable this periodic blinking notification?
08-19-2021 07:49 PM - edited 08-19-2021 07:51 PM
Not sure what you mean by "I have that setting configured" ? If you turn off 'Auto Power Off' in the System Setup menu then you won't get the blinking notification, obviously.
08-19-2021 08:23 PM
08-19-2021 08:23 PM
08-19-2021 09:34 PM - edited 08-19-2021 09:35 PM
"Auto power off" periodically flashing doesn't mean "auto power off is off".
It's intended to mean the exact opposite: auto power off is active.
Exactly. It's notifying you that the camcorder is about to (auto) power off.
