10-08-2021 03:40 PM
I need to be able to record on an SD card while simultaneously sending the signal out to an external monitor. Having read the manual (I am a newbie with the XA11), I cant find out how to do this or even if it is possible. Can anyone help?
10-09-2021 01:12 AM
Hi there,
You should be able to output a signal through HDMI while simultaneaously recording to the SD card, I dont believe this can be done through USB though.
10-09-2021 01:12 AM
Hi there,
10-16-2021 12:03 PM
Works as you suggest. Thanks.
