01-27-2015 12:23 AM
My Vixia g30 will not allow movies to be recorded to a 64 microsd card nor to a 128 micro Sd card, but will to a 32 microcard. I have not initialized the card as it is new. Would that be the problem, or is this too big a card?
01-27-2015 10:16 AM
I had to initialize the microsd card twice, but it is recording video just fine.
01-27-2015 01:27 AM
Not quite sure how you are using a microSD card in that camcorder. According to the specs and the manual it will support up to a 128GB SD card (not microSD). The acceptable types are SD/SDHC/SDXC and according to the manual the brands tested with the G30 are Panasonic, Toshiba and SanDisk.
01-27-2015 08:58 AM
01-27-2015 10:16 AM
01-27-2015 11:13 AM
Glad it worked and you found the solution. I thought you had used an adapter but the response was more in surprise that a microSD card (with an adapter) would work.
