06-28-2013 05:35 PM
I'm using a Vixia M52 camcorder. When I'm in manual shooting mode, I make adjustments to the white balance and exposure setting, however once I turn the camera to playback mode, it forgets the manual settings. How do I SAVE manual settings so I don't have to bother readjusting everything every time? Thanks in advance,
07-03-2013 06:16 PM
Hi Freeverse,
The settings should be retained in your camcorder when you turn it off. The only time an issue should occur is when if the battery is removed for a couple of weeks.
If this isn't the case, unfortunately, your camcorder requires repair.
You may set up the repair of your camcorder by clicking here.
