04-27-2014 03:48 PM - last edited on 09-12-2023 08:23 AM by Danny
Hello, I have been trying to set up the Wi-Fi functionality with my new camcorder for my iPhone and iPad. I have downloaded the CameraAccess app from the app store. In the camcorder setup I am not able to activate Wi-Fi, and the CameraAccess app cannot find the camcorder. I have read through all the documentation and am at a loss. I basically want to use my iPhone as a remote, and the iPad as a separate way to view what's recording. In the Monitor from Home settings, it does not seem to be active. Any suggestions welcome!
04-27-2014 09:04 PM
04-29-2014 12:26 PM
Hi dcleary and Meglorin!
Thanks for posting.
The specific function you are referring to is not available in the following cases:
- Video quality is set to 60P
- Dual recording or relay recording is activated
Please make sure neither of these is the case.
04-29-2014 12:29 PM
Thanks for the reply Mike!
I was able to get the WiFi to work by performing a factory reset but didn't know which of my preferred settings were causing it to not work.
I was shooting, prior to the reset, in 60P so that is my issue solved.
04-29-2014 05:20 PM
04-29-2014 05:21 PM
01-15-2016 02:44 PM
01-18-2016 05:43 PM
Hi Wumbon,
Before you begin, please check your camcorder settings to ensure that the date (including the year), time (24 hour clock), time zone and daylight savings settings are correct and match the settings of the network you're you're using for the connection, as well as your iPhone and iPad. If they don't match, you won't be able to make the connection.
Next, on your devices, please go to "Settings", choose "Privacy", then "Photos". Now, check to ensure that the Canon Camera Access App is enabled.
If you continue to encounter difficulty with this setting, please Contact Us.
02-20-2016 11:05 AM
I have a Vixia hf r60, and I hope the question is similar. I'm using a Android Droid Razr and having a hard time connecting the two. Any thoughts please?
02-22-2016 06:55 PM
