03-01-2019 06:43 PM
The manual only lists 4:2:0 while the Canon product page says there is an "OR" option suggesting both.
If yes, are these defaulted to by resolution or is there a compression option?
03-01-2019 09:57 PM
NickMDal,
When the XF400 is set to External Recording inside the menu, several options will become available for output only. It is here that options for 4K 4:2:2 8 bit 59.94 and 4K 4:2:0 8 bit 29.97 exist. 1920x1080 output settings for both frame rates is 4:2:2.
03-01-2019 09:57 PM
NickMDal,
03-02-2019 05:09 PM
Thanks for the answer. For 1080p output to HDMI only, does the recorder have to create a file using the ProRes or DNxHR codec?
I'm guessing that none of the Canon formats (raw, xf-avc) can be produced since there is no Canon hardware on the receiving end.
03-12-2019 11:31 PM
NickMDal,
The type of file created by the recorder will be dependent on the output and your specific workflow needs. So you will want to have this set in a manner which fits your output requirements.
03-17-2019 03:02 PM
Thank you for helping. I would greatly appreciate just a little more clarification.
Since this camera does not shot in log, I am wondering what the HDMI output will look like with regard to special scene modes. There is no option for a standard mode. I am thinking of using 3rd party LUTs to improve the color. What is the HDMI output like? It isn't raw. Is it like a 'standard' or 'faithful' scene mode?
