11-18-2018 06:21 PM
Its been 4 years since using this camera but I find after charing battery the unit does not film. I can take photos, but not film.This is true whether or not I use the "record button" or the "start/stop" display below the screen. Also, there is material on the disk but it does not display. Any thought on how to get the unit to read the HD?
Thanks,
Jimt
11-19-2018 06:22 PM - edited 11-19-2018 06:25 PM
Have you tried recording to an SDHC card to see if that will work? It is also possible that after 4 years the battery will not hold a sufficient charge to enable recording to the hard disc. Another thing to try is running the camera from the power adapter.
11-19-2018 09:46 PM
Thanks for your reply. I've tried recording to the SDHC and running with the power adapter, both meeting with negative results. There are no error messages and when I try recording there is no sound or camcorder vibration to indicate recording/working activity.
11-21-2018 11:41 AM
Not knowing this camcorder I can only guess. As you can take and I assume, playback photos it would indicate that the HD is working. Is there a setting you have missed which enables either video or pictures to be taken, but not both at the same time?
11-21-2018 12:20 PM
No, only able to use the card for photos. I'm thinking the hard disk simply does not respond to commands and probably crashed. I am going to keep playing with it.
