Reply
New Contributor
XF400 Face Detection Option Greyed Out
I'm wondering if you can help me with a setup problem. I cannot find a way to activate the Face Detection function in the menu. It is "greyed out." I have another XF400 set up identically (or so I believe) but it does not have this problem. Here are the exact settings:
CAMERA SETUP
digital zoom: off
zoom speed: normal
rocker: variable
handle: 8
wireless: 8
hi sp zm: on
af mode: cont
Af frame: s
Af speed: normal
af rest: normal
face: on!!!
focus guide: on
focus preset speed: normal
flicker reduct: off
Conversion lens: off
Image stab: standard
powered IS button: on
Set wb priority: 5600
focus ring direction: norm
focus ring resp: norm
zoom ring direction: norm
IR light: norm
IR Rec Color: white
RECORDING SETUP
Internal/External Rec: Internal
Movie Format: MP4!!!
Resolution: 4k
Frame Ratez: 59.94!!!
audio format: 4CH
Recording Media: Mem Card A
Recording Photos: Rem Card B
Dual/Relay Recording: Relay!!!
Available Space in Memory: N/A
Initialize: N/A
rec command: off
HDMI time code: off
Time code mode: preset
Time code running mode: recRun
DF/NDF: DF
Initial time code: n/a
User bit type: n/a
color bars: off
1 Khz ton: off
File numbering: continuous
AUDIO
CH2 Input: Input1!!!
CH3/CH4: int/mic
Input1 Mic Trimming: 0bd
Input1 Mic Att.: off
Input 1/2 limiter: Off
Input 1/2 ALC Link: SEP
Built in mic sens: Norm
Built in Mic Att: Off
Built in Mic low Cut: Off
Head phone vol: 8
Monitor Channels: 1/2
HDMI Channels: 1/2
Notification Sounds: Off
DISPLAY
Output Term: HDMI
HDMI Max Res: 1920x1080
Output Status: N/A
LCD Brightness: About 3/4
LCD Backlight: normal
VF backlight: normal
LCD Mirror Image: On
Output Onscreen Displays: Off
Onscreen Markers: Level White
Distance Unit: Feet
SYSTEM
Language: English
Time Zone/DST: nyc
Date/Time: Set as needed
Network Settings: N/a
Fan: On!!!
Wireless Remote: N/A
power led: On
tally lamp: on
access led: on
led: on
remote terminal: std
assign button1: af/mf
assign button2: powered IS
assign button3: preRec
assign button4: rec review
assign button5: magnify
Onscreen assignable button: photo
Custom Dial & Button Tv/Av/M!!!
Backup Menu Settings: N/A
Certification Logo display: N/A
Reset all: N/A
Re: XF400 Face Detection Option Greyed Out
stevesmede,
We are sorry that this is the case.  Other instances where this has become an issue, a full factory reset to factory default settings will relieve this issue.
Highlighted
New Contributor
Thanks for the quick reply, Tim!
I'll do that. I'm guessing now that the problem is NOT related to a setting issue, but is actually a technical malfunction? If so, I will pass that on to the rental house where I obtained it.
powered by Lithium
