06-26-2020 05:41 PM
I'm connecting an XA10 to a computer (Windows) via HDMI with a video capture card, to use the XA10 as a remote camera for a livestream event, but when I connect everything the HDMI output drops to only 480 rather than the 1080 I have it set to push out.
As you can see in the video below, I have the HDMI output set to 1080, but when I attach the capture card to the computer, that setting greys out and the HDMI status says it's only pushing out 480. And I can visually confirm on the computer that the feed is SD and not FHD.
I don't know the manufacturer of the camera card. It's NOT Elgato's product. It's a lower-cost knock-off that I bought from the The Camera Store in Calgary, Canada. I'm working through troubleshooting with them; they say they've never had a customer report this problem before. FWIW, looks like the same card is sold on Amazon by MavisLink, but I suspect they're just using the same manufacturer as the The Camera Store.
I'm wondering if there's some particular setting in the XA10 I should be paying attention to. I've gone through the menus a million times, though, and nothing is popping out. Thoughts?
07-06-2020 10:52 AM
Found my solution: Get a better capture card. The HDMI output works just fine with the Elgato Cam Link 4K. You get what you pay for, I guess. I exchanged the knock-off card for the Elgato and all is now well.
06-27-2020 10:15 AM
I found a few reviews where others said theirs only worked at 480p as well.
What software did you install on the PC?
Have you tried on another machine?
Different HDMI cable, etc?
~CarePaks Are Worth It
06-27-2020 10:32 AM
07-06-2020 10:52 AM
02-03-2021 05:14 PM
They must have upgraded the cheap knock offs recently or some brands of knock offs are better than others.
I was having the same issue as you.
The HDMI output dropping to 720x480 when trying to using cheap knock offs.
I have two of same style you tried. One worked, the other didn't.
After I found the one that worked I bought a second and it worked as well.
The $17 DIGITNOW USB 2.0 HDMI capture card I bought off of Amazon currently works for me.
07-29-2020 02:15 AM
