Reply
Highlighted
New Contributor
Accepted Solution
Vixia HFg40 for live stream (webcam)
HI all,
I purchased a Vixi HF G40 and was told I could use it to livestream through my computer. I can't figure out how to do it. I feel as if thegre is a menu setting that I am missing.
It doesn't work via HDMI at all (the internet says HDMI on a computer is out only, so that makes sense.
I connect via USB and have it the on/off swicth set to "camera," and windows doesn't recognize it at all.
I connect and turn it to "media"  and the windows thinks its a disk drive.
Any advice would be most appreciated.
Thanks,
Jack
Highlighted
VIP
Re: Vixia HFg40 for live stream (webcam)
Did the salesperson tell you that?  I would go ask that person.  I do not know if the model can do "live stream" or not.  I do know that my son and his wife somehow turned their HF-G62 into a baby cam, so they can monitor the baby's crib from anywhere on the house on their iPhones.
Highlighted
Valued Contributor
You may need a video capture device to livestream with the VIXIA HF-G40.  The capture device would go between the computer and the camcorder.  As has already mentioned, ask the person who told you this how it can be done.  There are some video capture cards that have an HDMI in port.
Highlighted
New Contributor
Thanks everyone. I spoke to canon and I do, indeed, need a video cature device. I was simply misinformed.
I've purchased one and hopefully things will work as I want.
Jack
Highlighted
New Contributor
Sir:
Would you please recommend a video capture device for my Vixia HF G40.  I am attempting to figure out how to stream on Facebook.  So far no luck.
Thank you,
David
Highlighted
New Contributor
Did anyone figure out if livestreaming is possible with the vixa hf g40 and a capture device? I habe both but i am still having no luck. Any suggestions?
Highlighted
Valued Contributor
What capture device do you have?  What have you tried so far?  Be as specific as possible.
Highlighted
New Contributor
When I connect the camera to a monitor I have no problem getting a picture.
I have two different capture devices. The first one is -
Electop Video Capture Devices HDMI to USB 3.0 Full HD Live Video Capture Game Capture Recording Box Dual HDMI USB 3.0 Adapter Video & Audio Grabber for XBOX PS4
When I connect the camera to the compture via this device I can find the device in OBS but it does not give a picture. It also does not display anyting on the monitor.
The second device I have is the elgato HD60S. When I connect the camera to this device it does NOT find it in OBS and it does not find a picture in the software download for the device.
I have tried my DLSR camera with both devices and it will pick it up for streaming. I cannot get it to find the Vixia HF G40 video camera. I have tried changing the FPS on both the camera and OBS and I am still having no luck.
The HDMI Status on the camers just has lines on both the video and audio output.
Highlighted
Occasional Contributor
Highlighted
New Contributor
What did you do to get it to wor? Did you change any of the setting on the camera?
powered by Lithium
