Reply
Highlighted
New Contributor
Accepted Solution
Canon XC15 and Video Converter for Adobe Premiere Elements 2019
Just acquired a Canon XC15 camcorder.  Have good background in photograhy and wanted to learn a little about video filmaking.  It appears the output of the XC15 cannot be edited in Premiere Elements 2019 without converting it to some other format.
It looks like Wondershare Video Converter Ultimate might be a good tool for converting the XC15 output to somthing like MP4 or MOV.
Anyone have any experience with the Wondershare converter and will it convert the XC15 video?
Second question, what is the recommended output format for editing in Premiere Elements?  Or does it even make a difference?
Any thoughts would be appreciated.
Rod Stafford
Frequent Contributor
Re: Canon XC15 and Video Converter for Adobe Premiere Elements 2019
The problem with Premiere Elements is it not being able to import XF-AVC files. Your camera can shoot in MPEG 4 which Elements can import. Not knowing the XC15 I don't know if the MPEG4 option is HD only and not 4k. There is this converter  for XF-AVC MXF, but the resulting files may only be readable by Premiere Pro.
https://www.transfermyvideofiles.com/best-xf-avc-converter-for-mac-pc/
Legria HF G40 - Zoom H2n - Dell 8700 i7-4790 3.6Ghz, 24Gb RAM, nVidia GTX 1060 6GB - Win 10 - DaVinci Resolve 16.1b1.
New Contributor
The only output from the XC15 is the XMF format.  Can't find anything in the user's guide or in any of the menus that gives an option to change the output.
Went ahead and downloaded Wondershare Video Converter and it works well in converting the video files to MP4 or MOV or a number of other formats.
Of course, Premiere Elements 2019 will read the file after conversion so problem solved.
A little surprised the XC15 has just that output.  Guess I should have researched it a bit more prior to purchasing but I do like the camcorder and having the converter is a good workaround.
Thanks for input.
powered by Lithium
