Reply
Highlighted
New Contributor
Accepted Solution
Canon Vixia - Zoom out problem, pleeeeeease help!
[ Edited ]
Hello all,
I have a Canon Vixia HF G40, brand new, a few months use.
It has started to zoom out automatically..  randomly I zoom in on a shot,, randomly (not always) it decides to zoom out on its own. Extremely annoying, I literally (sometimes) must keep my hand on the zoom button to prevent it from zooming out... I really don't understand what the purpose is, if this is a configuration issue. Where the hell can I go or do to stop this from happenning ?
thanks
Sandra
Highlighted
Frequent Contributor
Re: Canon Vixia - Zoom out problem, pleeeeeease help!
[ Edited ]
I have a G40 with no problems. Random zooming would suggest a fault with the zoom rocker switch. If it's less than a year old it should still be under warrenty.
Legria HF G40 - Zoom H2n - Dell 8700 i7-4790 3.6Ghz, 24Gb RAM, nVidia GTX 1060 6GB - Win 10 - DaVinci Resolve 16.1.2.
Highlighted
New Contributor
Cheers IamintheUK
I will check the warrenty solution.
Does this mean this could be a mechanical issue ? I thought maybe the Autofocus configuration is not doing its job... or any other software issue...
Highlighted
Moderator
Hello serazoo,
We encourage you to reach out to support for troubleshooting. Here in the USA, we're at 1-800-OK-CANON (800-652-2666). Outside of the USA, CLICK HERE for options.
Highlighted
If you look at some of the other threads here it seems to be a common problem.
Highlighted
New Contributor
I am having the same issue so it appears its a known problem with this type of rocker zoom switch.  Like yours, mine zooms all the way out and can only be stopped by light pressure on the zoom switch.  My guess is this is an issue that needs a recall to correct whatever is causing this malfunction.
At first I thought it was trying to autofocus the image but I troubleshot it some and soon realized it was a rocker issue.
I did a reset on all the settings and still the same.  Rocker Zoom issue.
Canon, please find a fix quickly.
Bob
Highlighted
New Contributor
Same camera , same problem , please help meeee!
Highlighted
New Contributor
Vixia G30 - same problem!
Highlighted
Occasional Contributor
Zoom function is very important, I hope it still have technical warranty. I gues the configuration function has something to do with it.
Highlighted
New Contributor
Canon fixed the problem, for $407
powered by Lithium
