Reply
Occasional Contributor
Canon Vixia HF R800 - is there a max storage limit?
Hello,
I picked up a 512 GB SD card from Amazon today that doesn't seem to be able to work with my Canon Vixia HF R800.
The usual formatting option is grayed out and I variously receive errors about the SD card being write protected or unreadable.
I can't think of two potential explanations:
1) It's a micro SD card with an SD adapter and Canon says that these tend to be more problematic than simply using a full sized SD.
2) 512 GB is larger storage than can work with the camera's firmware.
I didn't seem any mention of max storage capacities on the camera's spec sheet - only the recommended storage class.
Does anybody know if such a limited exists - and if so what it is?
Reputable Contributor
Re: Canon Vixia HF R800 - is there a max storage limit?
I cannot speak to that particular model, but when I had my Vixia HF G50, I was able to use full size SanDisk UHS-I V30 256 GB cards without any issue.  With G20 and I think the G10, I used 128 GB versions of those cards at the time without issue.
Possible there would be a problem with 512 or larger, but I would first suspect the micro SD card size.  Those are notorious for causing issues with photo or video gear.
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS
I found a few 256 GB cards on Amazon that specifically say they're compatible with the HF R800.... so yeah I guess it must be the micro SD thing.
powered by Lithium
