Reply
Highlighted
New Contributor
Canon VIXIA HF G20 - Problem with inverted image
Project: I created a welcome video
I cannot find the "correct setting" that will allow my eyes to be CENTERED into the lens, and my shirt pocket appearing on the CORRECT side during playback. Ultimately, I want the playback of video to capture what the camera "actually" sees, and not reverse it.
The two settings I've been using to address this are, Scan Reverse Rec and LCD Mirror Image. Here are the adjustments I used and the outcome of each:
Scan Reverse Rec - Off
LCD Mirror Image - Off
1. Eyes and body NOT centered into the lens.
2. Shirt pocket on the CORRECT side.
Scan Reverse Rec - Horizontal
LCD Mirror Image - On
1. Eyes and body CENTERED into the lens.
2. Shirt pocket on the WRONG side.
Auto Mode
Frequent Contributor
Re: Canon VIXIA HF G20 - Problem with inverted image
[ Edited ]
Your explanation is somewhat confusing. Do bear in mind that the LCD screen has no bearing on what is recorded. However this is how I interpret it. With the camera at its' default settings you want yor eyes centered and the pocket to be on the left hand side. At the moment you see the pocket on the right hand side. This would be correct as the camera, just like someone standing in front of you, would see it that way. If you want it from your perspective, the easiest way is to horizontally flip the image in edit software. If your eyes were only centered with the image one way it means you were not central to the lens in the first place.
Legria HF G40 - Zoom H2n - Dell 8700 i7-4790 3.6Ghz, 24Gb RAM, nVidia GTX 1060 6GB - Win 10 - DaVinci Resolve 16.1b2.
powered by Lithium
