02-22-2024
10:03 AM
10:07 AM
Is the following software still needed after printer install?
I'm recently retired (one year ago) and for the first time in forever, I needed to print something at home without having the office printer anymore... so I broke down and bought a Canon PIXMA TS 7720. Small but perfect for my limited needs.
It has been over 15 years since I've had a printer installed on my Mac, so I know what I see is something different from back then. The printer connects wireless to the Mac (not sure if that matters for what I am about to ask).
There are two new items in the Mac Finder that are showing up alongside my various drives. I believe the "mms2-mac-102_0_1-ea21_3" was for install only, and I am assuming that it can now be removed, correct?
The other item is "Canon Inkjet Smart Connect". Is this something required if I occasionally just send a PDF wirelessly to the printer?
Asking simply because I like to keep the clutter off of my Mac. The two items are the silver drives in the image below.
Thanks!
02-22-2024 10:07 AM
Yes, those items are virtual disk images presumably from .dmg files that contain the installation software. You can either single-click on those items, then choose "Eject" from the File menu within Finder. Or, right-click (Control-click) on those items and choose the "Eject <filename>" item. Or, click and drag those icons to the Trash (if you do this, the Trash icon will change to an Eject icon).
02-22-2024 10:07 AM
02-22-2024 10:13 AM
Yessir, I know how to remove them, I just wasn't sure if they were required at this point. Since this is just an entry level printer, install was shockingly clunky and slow, so I didn't want to go through all of that again.
Thanks for the quick reply, Ricky!
