"Device USBPRINT\CanonMG5600_series\7&62427ce&0&USB001 requires further installation."
Q2
Running WIN10.  No communication between MG5620 and my laptop.  WIFI powered by AT&T.  Printer is communicating with ATT router.  Missing MG5620 software - see subject - none of Canon support sites (except this one) will open up for me.  Is it a driver?  Is it Win10?  Is it my laptop?  Have never had so much trouble with Canon products which are usually fairly reliable!
1 REPLY 1
Ramona
Hi Q2,
Installing the latest drivers from the Canon USA may resolve the issue being experienced.  Please click here to go to the Drivers and Downloads page for the PIXMA MG5620.  Once on the page for the printer, please do the following:
1. Verify that the operating system detected in the "OPERATING SYSTEM" field is correct, and if it is not, please click the drop-down menu to select your operating system. Please note that you may need to scroll up or down in the list to select your operating system.
2. Next, below the red box labeled "RECOMMENDED DOWNLOADS", locate the FULL DRIVER AND SOFTWARE PACKAGE file, then click the SELECT button to the right of the filename. When you do, a dark gray DOWNLOAD button will appear; below that, a checkbox will be shown asking you to agree to the terms of the disclaimer to continue with the download. Please click in that checkbox to agree to the terms. When you do, the dark gray DOWNLOAD button will turn red. Please click on the now red DOWNLOAD button; the file will start downloading. The time for the download process may vary depending on the speed of your Internet connection and the size of the file being downloaded.
Once you have downloaded the file, please temporarily disable any antivirus or firewall software that is on your computer and then double-click on the file and follow the prompts to install the printer and software on your computer.  This will install all drivers and software for the printer. The reason we have you temporarily disable the protection software is because sometimes it prevents the printer from being detected and installed successfully.  Once the printer is installed successfully, the protection software can be re-enabled.
Should you need further assistance, please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) and a Canon technical support representative will be happy to help.  There is no charge for this call.
