11-10-2013 04:30 PM
mx459 will not let me enter number in WEP key, in only allows symbols or letters. how do i enter numbers?
john
11-16-2013 03:33 PM
03-13-2017 11:16 PM
Thank you! You made me figure out somethign that should have been easier, and for that I am very grateful! 🙂 AAA+++
03-19-2018 09:13 PM
Mr. Hoffman,
Totally worth registering just to tell you this. Thank you sir for your concise and accurate directions. Took me all of five minutes to sort everything after reading your post. I would think that this would be the prefered method as the WPS button method often resets the router and everyone today seemingly has 15 devices already connected to the router. But on the bright side reseting my router let me update my security. Great job and cheers to you sir, thank you again.
03-23-2018 07:42 AM
Use the Symbol Button to toggle back and forth at the bottom right coner by the number 3 Its been a while Quite simple but someone had to show me to friend hope this helps if not I will run through it for you
03-23-2018 07:44 AM
use the Symbols Key down in ther right hand lower cornier to toggle by or is the number 3 key thank you hope this helps Daryl
09-08-2018 02:14 AM
I went looking for information on how to enter a wifi passcode using the LCD panel on the G4600 MFP (it's now 2018). It is poorly documented in the G4600 user manual. Cannon's official G4600 support information does not resolve the issue. John Hoffman's post from 2012, however, does resolve the issue for the G4600 in the same way as it would have done for the MX459.
One point to add to John's note: on the G4600 (maybe the other model too?), when entering numbers, an asterisk is shown on the LCD panel. Only when entering letters is the character visible to the user (and then only for an instant, before the display reverts to showing it as an asterisk). This is presumably because when entering letters, the user may need to press the key several times to cycle through the available letters for the selected key, whereas for numbers, there is only one possible result for a given key that is pressed.
04-01-2020 01:16 AM
04-15-2016 07:26 PM
That works for letters and numbers but my passcode has the symbol # and it always enters a space when I try to enter it.
05-28-2017 03:41 PM
06-03-2017 02:41 AM
On the MG5460 there is no asterisk key, you have to use Aa1 - the center key on the bottom row
06-29-2017 03:01 AM
