08-30-2013 07:06 PM
Printer goes to sleep and when I am trying to print the computer cannot find the printer. Printer and computer are connected to router. I have to restart printer?? Ridiculus.
08-30-2013 07:36 PM
Hi, lkoumis!
So that the Community can help you better, we will need to know exactly which operating system is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
09-07-2013 11:49 AM
I am running a win 7 64bit workstation. I don't what other info are relevant to the issue. Downloaded the latest canon software from the website. thanks.
09-15-2013 01:42 PM
Hi lkoumis,
With some routers, if activity is not detected on a device after a set period of time, the device will be removed from the routing table. When the printer enters standby, it also enables discontinuous reception to save power. This might cause the printer to be disconnected from the router when you attempt to print again.
To disable this feature:
If the device is still disconnected after a long period of inactivity, I recommend contacting your router manufacturer for some additional options or settings you can change within the router itself.
11-06-2013 11:17 AM
Any other options, MarkII? Any hint on what router settings could be causing the printer to appear offline and require a reset in order to be found? Frankly, this printer unavailable issue is making me miss my MX 822.
