mixing LAN and wireless devices, and making it work
leszekba
I have the MG7520 printer setup as a wireless device, being fed by an AP node. This node is hooked up to a router that has 2 hardwired computers also. My wireless devices work well with the printer in this configuration, but not the PC's. I can only get them to work if I reconfigure the printer as a LAN device. This is annoying to keep switching the setup each time. I had a Lexmark previously where I set it up as wireless, and the PC's found the device on the AP node. Is there some trick I can use to do the same with the Canon? Thank you!
1 REPLY 1
Michael
Hello.
The issue appears to be that the two computers are connected to a separate router/network than the Wi-Fi devices.  Please connect the devices to the same router so they can communicate properly.
If you continue to have difficulties with the connection, find more help at Contact Us.
