Reply
New Contributor
Accepted Solution
Windows 10 Pro laptops cannot print via network to MF8350cdn
Hi:
I have a Canon MF8350cdn on a Workgroup network.  The Windows 7 machines print to it without any problems.  The Windows 10 laptops send the job to the queue then the job just disappears from the queue as if it printed but it did not.  I've already tried uninstalling the Canon s/w and cfg. the printer using TCP/IP port, but still doesn't work.  I've tried turning of the Windows Firewall, but still doesn't work.  If I connect the laptops directly via USB cable they print.
Thanks for any insights!
Valued Contributor
Re: Windows 10 Pro laptops cannot print via network to MF8350cdn
[ Edited ]
Try this on one of the W10 PC's.
Start menu > Printers & Scanners (settings).
Uncheck > Let windows manage my default printer.  Now click the MF8350
Press the manage button, now select "Set As Default", then close
Test printing.  Report those results.
Rick
~6D2 (f/w 1.0.3) ~16-35mm f2.8L II, 50 f1.8 STM, 85 prime, 70-200 f2.8L IS II ~Sigma 24-70 f2.8 Art (f/w 2.0) ~Sigma 150-600 C + TC1401 1.4x (f/w 1.03) ~Speedlite 430 EX II ~DxO PhotoLab Elite ~DPP 4.8.20 ~Windows10 Pro nVidia GPU 1803 ~Android 8.1
New Contributor
[ Edited ]
Hi Shadowsports:
Didn't work.
Thanks,
Bob H.
Valued Contributor
[ Edited ]
Bob,
Still looking into this issue.  Please ensure you have post script driver selected for the printer.  Windows 10 often sends in XPS which is sometimes not supported.
Also can you verify what port the printer is using in W7 and then compare to W10.  And, do the W10 PC have any 3rd party software installed that might affect printing?  What program are the users trying to print documents from? Or are all apps affaected?
I've seen this behavior with W10 previously.  In one instance it was due to docs being sent and not being processed as post script.  Once we changed the driver, everything started printing.
In the other situation, the print spooler would crash (transparently) giving the appearance that a doc was sent and received, but then disappear from the print queue. In this case, a 3rd party app was crashing the spooler service.
Rick
New Contributor
Hi Rick:
Changing the driver worked.  I couldn't find a postscript driver for this printer but I changed it from one UFRII to another UFRII driver and it started printing.
Thank you!
Bob H.
Valued Contributor
Bob,
Happy to hear of your success!!  Glad I could help.
Cheers,
Rick
Highlighted
Hi Tropolis_Group
Based on the specfic issue, It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
powered by Lithium
