Reply
New Contributor
TS6120 Cant find scanner
Mac OSX 10.11.6 El Cap
Pixma TS6120 Prints wirelessly fine, unit sees my macbook, on same network, 99% signal strength...
From printer screen- scan to computer- choose my mac,  starts scan- Canon IJ Utility Lite opens, "An error occurred while communicating with the scanner."
Try to scan from within IJ Utility lite- same message
Thru Mac system prefs, printer/scanners, choose TS6120, go from 'print' tab to 'scan' tab- open scanner, waiting for scanner, "error occurred -9923" (see image below)
Called tech support, tech had me uninstall printer, reboot router, reboot mac, reboot printer, reconnect... nothing
Had me just try to 'add printer' thru system prefs, wouldnt work- told me its a mac problem, cant help, call them.  Left me with NO printer and no scanner
I hung up, reinstalled the printer using exact instructions that came with the printer-
Im back to where I started.  Wireless print works fine, NO SCAN
anybody???
Re: TS6120 Cant find scanner
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
New Contributor
already contacted tech support at Canon...
after uninstalling my printer, he ws not even able to get it to re-install with his method. Told me it was a mac problem.
I hung up and re-installed according to instructions that came with the printer just fine.
Now back to wirless printing fine, NO wireles scan
Highlighted
New Contributor
SOLVED!!!
Dual band router…  5 ghz/ 2.4 ghz
set wifi on the macbook pro to 5 ghz, changed name and set the printer to the 2.4 ghz band… voila!  Scanning wirelessly, no problem.
powered by Lithium
