Reply
New Contributor
Support Code : 300 The printer does not respond. printer will not print wireless
Support Code : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
Think I need to do something to the printer as I reset to factory settings and now nothing
Hope someone can help please ?
New Contributor
Re: Support Code : 300 The printer does not respond. printer will not print wireless
Try to delete and then re-add your printer again. For instructions on how to perform that, refer to the link below. I once had this issue and managed to fix it by re-adding my printer. Hope it works for you.
Techyv - Support Code 300
New Contributor
Have you fixed this?
This is the second time I've had this issue.
The first time was the airport, it was on the fritz so I replaced it and it was fine. That was a month and a half ago.
Here it is again.
The printer has power. I turned it off and on.
I unplugged the airport and plugged it back in. unsolved
I restarted my computer, deleted all jobs from the que and tried to print again.
I went in deleted the printer from preferences and now NO printer is available.
I need reliability, any thoughts?
New Contributor
I had to reinstall the setup. Ugh.
New Contributor
I had the same problem recently.  I deleted the printer on my mac and then pressed the +button to reinstall it.  Nothing happend.  What finally worked was to go to Canon downloads and support and reinstall the drivers.  Then when I hit + the printer reappeared on the list.  I reinstalled it, and everything worked fine, for now anyway.
powered by Lithium
