Pixma MG5420 WiFi connection problem
Hal2k
The WiFi (WLAN) set-up works good all day after it starts.   But overnight when the printer is inactive it looses it.  When trying to print first thing in the morning I have to re-configure it using the "Standard Setup" method which involves typing in my WiFi password (a long and cumbersome process).  This machine is new (only 3 days old) and maybe this problem will eventually go away, but it hasn't for the last two mornings.   Anybody have this problem?  If so, how to fix?  Thanks.
Hi Hal2k,
Yea, unfortunately you can't attach a word document or a text file, just a picture or video, but the 54% you are getting can definately account for the issues you are having.  Optimally you want that number to be around 70 to 80% if not better.  If at all possible I'd recommend moving the printer closer to where the router is, but if that's not possible you can try two things, one would be to access your router settings and try changing the wireless channel that your router transmits on.  If you are in an apartment complex or if you are in a neighborhood with other people who have strong enough wireless routers their signals can be overlapping yours causing signal loss and switching to a less crowded channel will help that.  If moving the printer or the router so that they are closer to eachother is not an option, your other option would be to purchase a wirelses extender that will strengthen the connection between your printer and router.
55 REPLIES 55
Karl1
Rising Star
Hi Hal2k,
So that we can better isolate the issue, I would like to see what happens when you unplug the router and plug it back in instead of reconfiguring the printer.  The printer should be retaining the wireless settings, so I suspect what is happening is that the router is losing connection with the printer, and power cycling the router and seeing if it prints afterward will help us determine that.
I've got 2 computers, 1 iPad and 2 iPhones in my synced WiFi system.  I've partially solved my problem
by connecting one computer to the printer with USB.  It works great.  The other computer started to
work wirelessly on it's own without any further help from me, as did the iPad.  However, the 2 iPhones still
do not work and all I get on them is a message  saying "No AirPrint Printers Found".  They both have
iOS 6.1 as does the iPad.  Rebooting the printer didn't help.
Meant to say Rebooting the Router doesn't work.
Hi Hal2k,
Since the router appears to be OK, I would like to see how the printer's connnection looks.   To check this, use the following steps to print the LAN details on the printer:
1.  Select Setup on the Home screen.
2.  Select  Device settings, then press the OK button..
3.  Use the up or down button to select LAN settings, then press the OK button.
4.  Use the up or down button to select Confirm LAN settings, then press the OK button.
5.  Use the up or down button to select Print LAN details, then press the OK button to confirm the selection.
6.  Use the  up or down button to select Yes, then press the OK button to start printing.
What is it showing for the link quality and signal strength?
Signal strength is 54%. " Link quality" not shown on the print-out.  Other possible appropriate readings are:
Connection/Active, Channel/10, Subnet Prefix Length/64, Wireless LAN DRX/Enable, Authentication/WPA-PSK, Encription/ TKIP, plus other stuff in the "Wireless LAN" section.  Also an "Other Settings" section which doesn't appear significant for this purpose.
I haven't discovered a way to attach a file to this message.  If doable, let me know how and I'lll send you the whole  print-out.
just bought a Pixma MX432:  also cannot figure out how to connect wireless....helo!  Tried calling 800 #.
Hi Hal2k,
I have been attempting to print for sometime.  Have had the Canon MG5420 for several months and it worked great until today.  All of my computers are unable to "find printing device."  Have completed advanced wireless setup several times with password.  Printer confirms it has connected each time.  I have turned the printer off to reset, still is unable to be found by my computers and iphone.  Completed a printing of the Network Configuration Page and it shows that signal strength is at 96%.  Suggestions on where I go from here?
Thanks.....
Purchased PIXMA MG5420 a week ago. Several times after setting up WiFi connection I have had to go through setup again and again. Called Canon Support this afternoon and tech insists that my Cisco router is the reason the connection is being lost. Re-installed drivers with tech help. Thought problem was solved. WRONG. Connection dropped again several hours later. Using Dell Windows Vista laptop. I have a Lexmark wireless printer (not air printer) that never has this problem.
Suggestions to solve this problem appreciated. Note laptop and iPad (reason I bought Canon printer) are NEVER dropped by router, so I do not accept Support's claim that my router is to blame.
Enter for a chance to win!
April 20th-28th
