12-18-2017 08:56 PM
Just bought this printer. Set it the wireless connection on each of two laptops. t worked fine the first time. The next day when we tried to print from either printer, we get a "Printer not connected" error. We went through the add printer steps as described in the manual again. Again they worked, but the next day got the same error. So noe we need to either figure this out or return the printer. Any help will be appreciated.
12-22-2017 09:41 AM
OK, I found the terminal and got this:
Michaels-MacBook-Air-2:~ michaelburns$ ping whateverIPaddressyouwant
ping: cannot resolve whateverIPaddressyouwant: Unknown host
In Utilies there is also a folder for the Canon IJ. I am going to install again (for the third time!) and go to that Utility to see if I can figure out how to make it have a static IP address
12-22-2017 10:14 AM - edited 12-22-2017 10:18 AM
When you are pinging a device,, you have to specify the IP... the IP of my printer is 192.168.1.99.... When I ping it, it replies.
C:\Users\admin>ping 192.168.1.99
Pinging 192.168.1.99 with 32 bytes of data:
Reply from 192.168.1.99: bytes=32 time=1ms TTL=255
Reply from 192.168.1.99: bytes=32 time=2ms TTL=255
Ping statistics for 192.168.1.99:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 2ms, Average = 1ms
the >ipconfig /all
command ( and there is a space between the ipconfig and forwad slash) .... gives you the information I referenced previously. Your gateway IP address is probably going to be one of these. Guessing, but pretty sure.
192.168.1.1
192.168.0.1
10.0.0.1
You can confirm using the command above to see the output. But one of those 4 entered into your browser wil likely get you to the log in for your router.
~CarePaks Are Worth It
12-22-2017 10:47 AM
when I did the ping 192.168.0.1 it pinged (the router? and gave me the time over and over until I stopped with control-C. Then I tried this:
Michaels-MacBook-Air-2:~ michaelburns$ ipconfig /all
usage: ipconfig <command> <args>
where <command> is one of waitall, getifaddr, ifcount, getoption, getpacket, getv6packet, set, setverbose
In this day of plug and play devices I am amazed that this is happening
12-22-2017 11:08 AM
If you were here you would have figured it out instantly I think.
On the printer home screen there is an ico for settings. There was a little box that said "new" and it indicated that the printer did not have the latest firmware. Once that was downloaded it worked fine.
Thanks again for your efforts.
