Never able to get MX494 to work properly
entreprenewer
  • MX494 PIXMA - firmware up to date
  • Mac OS X latest version
  • Timecapsule Airport
  • DRX setting Inactive
  • Access control OFF
Able to connect to network, but it shuts off after a time. Shows on OS X, but printer doesn't respond.
I literally am NEVER able to get this printer to work... and the rare occasions when it HAS worked, it disconnects after a a few seconds, minutes, hours, or days.
HOW do I make it work?
4 REPLIES 4
entreprenewer
I've also tried setting up with an iPhone, nothing works. Literally nothing.
When I print network settings, it as an IPv4 and IPv6 address... but nothing.
entreprenewer
And after a while, it just disconnects and shows an X on the wifi logo. This printer is IMPOSSIBLE!
Hi entreprenewer,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
entreprenewer
You won't believe what the issue was...
I had the printer and the router hooked up to the same electrical socket with a power strip...
Ran a cable to another power outlet - problem solved.
