Reply
New Contributor
Re: MX922 loses wireless connection
Hi
   I had the same problem after talking to Canon they told me to disable the Ipv6 Ip.
Go to settings and disable the ipv6 and should solve the problem. Ipv6 was interfering with the ip and wouldn't allow the printer to keep an Ip.
                     good Luck
                        Bob
New Contributor
My MX922 had exactly the same problem; it dropped its connection to the router in 5-10 minutes and the only way to reestablish the connection was to power the MX922 down and power it up.  I was using a DLink DI-825 router.  I tried all of the cures described on the web and on this forum - static IP addresses, disabling ip6 addresses etc. nothing worked.  I gave up and just powered  the printer off and back on every time I planned to use it.
I recently replaced the router with a with a Netgear Nighthawk R7000.  The problem of the MX922 dropping its wi-fi connection disappeared completely.   I haven't had to power it off and on since the day I started using the new router.
For the record everyone in my household connects using Windows 7 or 8,1 and Android 4.2 and 5.0.
Occasional Contributor
Here's what worked for me.  My router channel was set to "automatic".  When I set it to a specific channel, the same channel that the printer was reporting as its channel, I was able to connect and print without a problem.  There was also a checkbox that said to keep the setting during power cycles, and I checked that.
CLH
New Contributor
Don't know whether this will help those with sleeping MX922's, but will put my experience out there.
I bought a Canon MX922 in December 2014 and began to have wireless communications problems that started between my Windows 8.1 OS based computer and the printer after seveal months of use. The computer would lose communication  with the printer; but could be re-iniated by re-installing the driver software on the computer.
Communication would only last for several days and then the printer would go silent (asleep) again and re-installation of software would begin again.
I also had an older computer running Windows XP connected to the same wireless U-VERSE gateway by cable (ethernet). It was apparently not affected by the wireless communications between the Windows 8.1 OS machine and printer. From this, it appeared to be a problem with the wireless machine running Windows 8.1 OS and its communication with the Canon MX922.
I called Canon and went through several extensive "song and dance" sessions which accomplished nothing. Everything they suggesed PASSED as computers, gateway, and printers are all in the same room and signal levels on all machines are 100%. However, this never stopped the printer from going to sleep.
Later, I inadvertantly discovered what the "printer" problem was in a failure of wireless communication between my computer and the Canon MX922 printer.
I discovered this from Norton when Norton 360 informed me that they could not run an update on my Windows 8.1 OS computer.
Norton then suggested that I UNLOCK FAST STARTUP on the Windows 8.1 based computer. (This can be found under the Control Panel in Power Options).
For some reason after unlocking the FAST STARTUP, the Printer Folder in the computer created a secondary MX922 Copy.
I deleted this secondary Canon MX922 Copy leaving the original alone.
After this, correct communication and operation between computer and printer occured. I have been using this configeration and it has worked ever since.
Apparently, the MX922 printer cannot handle (or at least was intermittant) in FAST STARTUP on the Windows 8.1 Operating System when each were in the wireless configuration!
New Contributor
HERE is the fix!!!!  Go to settings then LAN settings then other settings then " wireless LAN drx" and disable it.
Your printer will no longer disconnect!
This is a power saving feature that is malfunctioning.
Merry Christmas
New Contributor
All of my connection problems...every single one...went away when I upgrade my router. That's it. No settings changes on the printer or computer made any difference. Finally, I thought I'd bite the bullet and get rid of the $50 router I had and get a $200 Nighthawk. Boom - immediately all the issues were gone. I barely even think about it any more. Now, when I want to print something, the printer shows as active and I send my kids in to get the printout (usually it is something for their school). Perfect.
New Contributor
Nighthawk with stock firmware handles the mx922 fine. If you ever decide to go to xwrt vortex merlin firmware on the r7000 you will have to disable "wireless lan drx"
New Contributor
AMAZING! EUREKA! Thank you so much josepena64!! Changing our Verizon Router to use Channel 6 got our MX922 to work like it should over wireless.
I dedicated my username to you!
Note - if you're not a technical person please don't attempt altering your router in any way - get someone who knows how to do it.
New Contributor
I was having a similar problem with another Canon printer model (MG5420) which had been printing wirelessly for months from a variety of devices on my network, then suddenly lost the ability to print wirelessly.
After implementing a number of suggested fixes from Canon Support* which did not resolve the problem, I checked every single router setting I could find to see if something looked off. After I disabled an "enable wireless isolation" function, the printer began printing wirelessly again.
So for those who suddenly lose wireless printing ability, check router settings.
*even though they didn't come up with the ultimate fix, Canon Support was there on the weekend, responsive, polite and professional.
Article that might be helpful for others in the same boat:
http://helpdeskgeek.com/networking/how-to-troubleshoot-wifi-wireless-printers/
Here's another possible cause for the problem.  Today, I connected remotely to my office from my PC with a secure VPN connection.  The printer wasn't responding during the secure connection, and even after I closed the connection, not even from a Mac laptop.  I tried rebooting the router and the printer and nothing worked.  Finally, I shutdown everything and restarted, and printing started working, even for the Mac laptop.  I haven't completely figured it out yet, but I think that the secure connection did something to the router that affected the printer, until I shutdown the PC that I was using for the secure connection.  I've noticed this before, that sometimes the secure connection seems to affect the wireless network, but I haven't figured out what it is, only that shutting down the PC that had the secure connection seems to fix the problem.
powered by Lithium
