Reply
Frequent Contributor
Re: MX922 goes to sleep and loses WiFi connection
Clarification. If you sign the static ip address outside the DHCP range, you wouldnt have to reset the printer. As stated previously, once I assigned static ip address outside of DHCP range, I have never had an issue and it has been years
Occasional Contributor
If assigning a static IP address problem fixes your wifi-connected MX922 then you got lucky and don't have the same problem as other people have with their wifi-connected MX922s. My printer has had a static IP address since its very first day and it still randomly loses its wifi connection after going to sleep. In other words, if you've got a MX922 which goes to sleep and can't be remotely woken up (either via a local print job, or a cloud print job), then the static IP workaround doesn't help.
Highlighted
Is your ip address outside the DHCP range
[ Edited ]
1. many routers do NOT allow assigning static IP addresses outside of their assigned DHCP range.
2. this workaround does not always work. I and others have repeatedly responded that we still have MX922 wifi problems even though we've configured the printer with a static IP address.
3. not all MX922 printers seem to be affected by the wifi-falls-down-and-can't-get-up problem. You apparently got lucky and got a MX922 that doesn't really have the same wifi problem. Rather it appears to me that you've got a buggy DHCP server that doesn't know how to manage its pool correctly and/or have a DHCP server that doesn't pay attention to the ARP messages from other systems which should clue it into that a IP address it thinks is available is still in use. Some older (unpatched) Windows-based DHCP servers and some older DSL/Cable-routers have this problem.
I have had the vo to sleep problem many times and tried many fixes and my router is fine. Since assigning static IP address outside of DHCP, I have never had a problem in years. If for some reason one can not assign outside DHCP, then just have to recycle when that original ip address is taken during sleep mode
Valued Contributor
[ Edited ]
Static IP - Inside or outside the DHCP pool...  doesn't matter.  If you reseve the IP by the devices MAC address the router will always give that device, and no other the designated IP. Use whatever scheme your device supports.
Setting a static IP address for a network device is by no means a "workaround".  Its standard practice in the industry and manditory for successful network administration and management.
The same rules apply for consumer networks powerd by soho and pro-sumer grade networking equpmemt.  The consumer grade boxes provided by comcast, charter, time warner, verizon, AT&T, etc. are junk.  These companies are not concerned about providing you with a robust secure network...  they are selling you TV, phone and internet at the highest profit margins possible.  That includes making you rent their garbage networking equipment on a monthly basis.  Don't expect much from these devices.
So your statement, " if you've got a MX922 which goes to sleep and can't be remotely woken up (either via a local print job, or a cloud print job), then the static IP workaround doesn't help." is not something I'm going to bother debating.  You must have a unique environment the fundemental rules of networking don't apply to.  If you cannot ping your printer using its statically assigned IP 100% of the time, I suggest you look at replacing the equipment powering your networlk.
From your post, I see clearly that you have a deeper understanding of networking, but if your equipment doesn't retain ARP information correctly, it's pretty worthless.
Rick
~6D2 (f/w 1.0.3) ~16-35mm f2.8L II, 50 f1.8 STM, 85 prime, 70-200 f2.8L IS II ~Sigma 24-70 f2.8 Art (f/w 2.0) ~Sigma 150-600 C (f/w 1.03)
~Speedlite 430 EX II ~DPP 4.8.20 ~Windows10 Pro nVidia GPU 1709 ~Nexus6P Oreo 8.1 ~Samsung s9+ Oreo 8.0
New Contributor
I recently developed this problem.  After trying numerous items suggested in this message string, I called Canon Customer Support.  They recommended resetting the router, which did nothing.  Then, I ran the Canon network utility and it identified a problem with the port on the computer.  I corrected that problem and the WiFi disconnect problem is gone.
powered by Lithium
