04-18-2013 04:54 PM
04-20-2013 12:00 PM
Hello loudorazio.
Unfortunately, the only supported network connection on the MX700 is an Ethernet connection. The MX700 does not have built-in Wi-Fi capabilities.
However, if you connected the printer to a Wi-Fi router that has Ethernet ports, you should be able to access the printer from a Wi-Fi computer that connects to the same router.
04-20-2013 12:00 PM
Hello loudorazio.
04-20-2013 12:51 PM
thanks for the info
