04-02-2014 12:54 PM
When I try to scan a document on my wireless printer the readout tells me "Local USB" . Does that mean that I have to connect a USB cable before I can scan and e-mail?
Thank you for any help.
04-03-2014 01:51 AM
I want to echo this sentiment. I have the Pixma MG5420, but I suspect the resolution will be the same.
The desired functionality is to scan a document, and then email it to a specified address without having to leave the printer. Is this possible?
I have read the Pixma manual entry on this, but found it hard to understand. It looks like the process involves first sending the document to a PC, and then using a specified program on the PC to email the scan. Is that correct?
01-12-2017 07:09 AM
I just purchased a CANON PIXMA printer/scanner. It appears I am not alone in trying to scan a document to my email account. Is there clear, concise information on this? Are there ANY prelimanary steps I need to take i.e., loading a WIZARD?; hitting a certain key?, etc???? Thanks
01-12-2017 11:23 AM
Hello.
Please review the following link for a section that covers setting up the Scan to E-mail function:
MG5500 Series Online Manual: Scanning to E-mail
02-04-2018 07:14 AM
@canon_PC wrote:I want to echo this sentiment. I have the Pixma MG5420, but I suspect the resolution will be the same.
04-04-2014 02:05 AM
@Dags wrote:When I try to scan a document on my wireless printer the readout tells me "Local USB" . Does that mean that I have to connect a USB cable before I can scan and e-mail?
I played around with this a bit more. When my computer was turned on, the printer would find it and list it below "Local USB." "Send to PC" would send the file to my downloads folder on my computer, while "Scan and email" would send the file to my downloads folder and open up Outlook with the file as an attachment. That was a little creepy, I have to admit, and pretty much useless.
When I turned my computer off, the only option on the printer was "Local USB," so presumably in your case the printer can't find any networked computer to send your file.
Hope that helps!
07-23-2017 02:28 AM
04-21-2014 04:12 PM
Hi Dags,
If trying to scan wirelessly, you will need to ensure that the IJ Network Scanner Selector EX is running. For information on launching and configuring the IJ Network Scanner Selector, please follow the steps at the link below:
PIXMA MG5520 Wireless Scanning - Launching the IJ Network Scanner Selector
Hope this helps!
04-24-2017 10:17 PM
05-31-2017 07:31 AM
How do I scan and email with my Canon Pixma MG2440 linked to my ACER System personal computer?
