DHCP not getting IP address from the wireless router
asayani
My Wi-Fi router broke so I replaced it with a  TP-LINK Archer C2 (AC750) wi-fi router.
I have not been able to connect my PIXMA MX532 to the wi-fi network.  Actually, it connects to the SSID that I select (I have done manual as well as WPS and in both ways, the printer connects to the network) but no IP address seems to be assigned to the printer. I have several laptops, phones, media servers, connected to this network so I know that it works and is able to give out DHCP addresses.
I even tried entering the IP address manually on the printer but that doesnt seem to change anything.  The pritner still doesn't connect to the network.
Please help.
Thanks
Ahmed
19 REPLIES 19
asayani
i just did a network setup while connected to USB and even in this case, the printer cannot get an IP address.  I also tried to manually enter IP address but the printer doesnt seem to take it.
I think there is possible a TCP/IP stack problem on the printer.  I am including the settings copied from the wizard.
What can be done?
Network Information
General Info.
(01)Date. . . . . . . . . . . . . . . . . : 2016/Mar/13 23:40:06
(02)Model . . . . . . . . . . . . . . . . : Canon MX530 series Printer
    (03)Printer . . . . . . . . . . . . . : USB Printer
        (04)BJNP Port Name. . . . . . . . : CNBJNP_D8492F73137F(192.168.0.112) Wireless
    (05)Scanner . . . . . . . . . . . . . : Canon MX530 series Network
    (07)Fax . . . . . . . . . . . . . . . : USB FAX
        (08)BJNPFAX Port Name . . . . . . : CNBJNPFAX_D8492F73137F(192.168.0.112) Wireless
(09)BJNP Port Monitor Version . . . . . . : 3.4.0.30
Application Info.
(11)Port Name . . . . . . . . . . . . . . : USB001
(12)BJNP Port Name. . . . . . . . . . . . : CNBJNP_D8492F73137F(192.168.0.112) Wireless
(13)BJNP Communication Module Version . . : 3.4.0.30
(14)Application Name. . . . . . . . . . . : Canon IJ Driver Installer; Set Printer IP Address(Wireless)
(15)Application Version . . . . . . . . . : 2.5.1.10
(16)Printer . . . . . . . . . . . . . . . : USB Printer
NIC Info.
(21)Printer . . . . . . . . . . . . . . . : Canon MX530 series Printer
(22)Firmware Version. . . . . . . . . . . : 3.010
    Wireless LAN
        (23)Wireless LAN Enabled. . . . . : YES
        (24)Standard. . . . . . . . . . . : 802.11n
        (25)MAC Address . . . . . . . . . : D8-49-2F-73-13-7F
        (26)Network Type. . . . . . . . . : Infrastructure
        (27)SSID. . . . . . . . . . . . . : linksys
        (29)Encryption ON . . . . . . . . : YES
        (30)Encryption Type . . . . . . . : AES
        (31)Authentication. . . . . . . . : WPA2-PSK
        (32)Attached Information. . . . . : 11 character Passphrase
        (33)Link Status . . . . . . . . . : Active
        (34)Signal Strength . . . . . . . : 100%
        (35)Link Quality. . . . . . . . . : 84%
      TCP/IP
        (36)Mode. . . . . . . . . . . . . : Manual
        (37)IP Address. . . . . . . . . . : 192.168.0.150
        (38)Subnet Mask . . . . . . . . . : 255.255.255.0
        (39)Default Gateway . . . . . . . : 192.168.0.1
(47)Admin Password ON . . . . . . . . . . : NO
    Printer Access Control
        (48)MAC Address Enable. . . . . . : NO
        (49)IP Address Enable . . . . . . : NO
(50)Device Status . . . . . . . . . . . . : Available
    Printer User Name
        (51)Wireless Name . . . . . . . . :
PC Info.
(61)SSID Info.
Wireless adapter Name . . . . . . . . . . : Intel(R) Wireless-N 7260
    SSID. . . . . . . . . . . . . . . . . : linksys
(62)IP Configuration Info.
Windows IP Configuration
   Host Name . . . . . . . . . . . . : PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 20-1A-06-08-EF-8E
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 5C-51-4F-39-E3-0C
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 5E-51-4F-39-E3-0B
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Intel(R) Wireless-N 7260
   Physical Address. . . . . . . . . : 5C-51-4F-39-E3-0B
   Link-local IPv6 Address . . . . . : fe80::e051:509a:9b00:d2dd%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Sunday, March 13, 2016 11:07:05 PM
   Lease Expires . . . . . . . . . . : Monday, March 14, 2016 1:09:31 AM
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.1
   DHCPv6 IAID . . . . . . . . . . . : 358371663
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-C2-DE-C0-20-1A-06-08-EF-8E
   DNS Servers . . . . . . . . . . . : 208.67.222.222
                                       208.67.220.220
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{D3BD3312-5EA9-4859-82E7-1D6CFE40EECF}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Link-local IPv6 Address . . . . . : fe80::285f:3d6a:e7fb:3402%5(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 385875968
   NetBIOS over Tcpip. . . . . . . . : Disabled
Ahmed
TCP/IP
What is that in bold type?  It looks like your printer's IP address.  Check your network security settings on your LAN, though..
The IP in bold is what I was trying to set manually using the USB cable because it was not able to set using DHCP from the router.  Even the manual step was failing constantly as the printer just wouldn't accept TCP/IP settings.
I even went to the controls on the printer and set the IP, SM, GW manually from the onboard keyboard.  The printer shows that the address was entered but when I do a printout of the current settings, the IP address section shows up blank and only DNS Server is listed.
Also of note is that when I do a Wi-Fi connection setup on the printer, it does connect to the access point and I do see the printer MAC address in the connected clients list on the router but when I look at the DHCP clients list, the printer does not show up.  All the other devices (laptops, phones, servers) show up in the DHCP clients list which means the printer makes the connection at L2 but is not working properly at L3.
It seems like for some reason the TCP/IP stack on the printer is not working as it is supposed to.  Both dynamic or manual.
-A
Assign the printer a fixed IP address from your router.  Make sure the printer is set for WiFi, and not USB.
I did all of that Waddizzle.  I have been working in IT since the 90s so I know my way around these things.
The next thing I am going to try tonight is to turn on network sharing on my phone and connect the printer to it to see if it behaves differently and receives an IP address dynamically from the phone.  Will update you.
-A
asayani -- did you ever figure this out?  I have an identical problem... seems to have been triggered by a similar router swap.  Spend 2 hours on the phone with tech support to no avail.  Tried everything you said too.  I'm losing my mind on this.
asayani and breichgott; did you ever get this DHCP problem sorted out? I'm having the exact same problem, although it's an iP8750 printer. I've searched the net far and wide, and so far haven't found any clues that can help...
asayani
Nope .. Ditched the printer
Ouch, that's bad! Sorry to hear that. 😞
