Reply
New Contributor
Re: Cannot connect to google cloud print
I agree. The problem is that Google changed CA's, and Canon has yet to update the firmware with the new GlobalSign CA's registered.
The 8500's let you upload cert files & register them. I assume this is mostly for enterprise funcitonality. In my case, I was desperately looking for a certificate file format the 8580 would swallow. So I went looking for sources. Because I'm pretty adept at MacOS, I knew Keychain Access was a possible source. So I went trolling for exports from KA for anything GlobalSign, and I discovered a format the printer would import.
I suspect all the Canon was missing was some sort of public key for GlobalSign's CA.
I can barely follow all the technicals you mentioned. I'm a total novice at encryption concepts. I just found a procedure that solved the problem I needed solved, and it didn't seem to matter whether or not SSL was enabled in the machine.
Highlighted
New Contributor
Thanks for the pointer to the CA certs!
Which certificates did you have to import to make it work in the end?
This is what I have now:
C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CAC=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA28/01 2028 14:00:00
OU=GlobalSign Root CA - R3, O=GlobalSign, CN=GlobalSignOU=GlobalSign Root CA - R3, O=GlobalSign, CN=GlobalSign18/03 2029 12:00:00
OU=GlobalSign Root CA - R2, O=GlobalSign, CN=GlobalSignOU=GlobalSign Root CA - R2, O=GlobalSign, CN=GlobalSign15/12 2021 10:00:00
The certificate chain for google.com is
Certificate chain
 0 s:/C=US/ST=California/L=Mountain View/O=Google Inc/CN=*.google.com
   i:/C=US/O=Google Trust Services/CN=Google Internet Authority G3
 1 s:/C=US/O=Google Trust Services/CN=Google Internet Authority G3
   i:/OU=GlobalSign Root CA - R2/O=GlobalSign/CN=GlobalSign
so I assume only the R2 one is needed, but I still get the "Failed to acquire information for registration." error.
New Contributor
Ok, got it to work by disabling IPv6. Thanks again!
New Contributor
My understanding was that the R2 was the only one needed as well. But I honestly can't remember which one did the trick. I went ahead and installed all of them thinking it coudn't hurt. :-)
Glad it was helpful to someone else.
New Contributor
Thank you JettCA11.
I have Canon MF8200C Series printer. Model is Canon imageCLASS MF8280Cw
I updated the firmware, it did not work
This has been frustrating problem I had from Jan of this year.
The errors I saw on the remote UI were:
"Failed to acquire information for registration"
"Could not perform server authentication"
Installing the certificate (Global Sign R2) allowed the registration and cloud print is working now.
Please note that I tried to export the cer file from internet explorer and firefox and it did not work. I had to extract the cer file from MAC and upload it.
New Contributor
Yes, you are right, It only worked when I uploaded and registered the GlobalSign Root CA - R2 certificate.
R3 and the plain Root CA did not work but I left them there anyway.
This is the only current solution to this problem based on my research online.
Thanks a tone.
powered by Lithium
