Reply
New Contributor
Re: Speedlite 600ex-rt battery problem
did you ever find a solution for this problem.  two out of my three 600-ex-rt's have just "developed" this problem after working for a year?  thank you.
New Contributor
did you find a solution to your problem with the "battery dead" symbol?
New Contributor
Same thing here. Strange. Thank you for this post
New Contributor
I just got my 600 EXRT and I put new batteries into the device and found the same issue. I called around and found a solution that could help you. I powered the device down. Next I held down the two clear buttons under the display and turned the device on. I then move the power switch to lock and the device began working. I believe it reset the system and cleared out the problem.
Hope this helps!
New Contributor
[ Edited ]
Hey guys,
I too have this issue.  I bought a new 600ex-rt from thecamerastore (calgary), and no atter what type of batteries I put in (duracel AA, or Energgizer Advanced lithium), I got the dead battery symbol.  This is hyper frustrating, I've tried everything so far suggested in the forums.  Anyone have any ideas?
New Contributor
I can confirm the above method of the reset with the clear screen hold, turn to on and then to hold.
It didn't work the first time, it took me 5-6 tries to do it.
New Contributor
Hi there,
i had the same problem, i tried with my Eneloop but got the battery indicator, then tried with some alkaline (duracell) and the same problem, however i left the alkaline batteries in for a few minutes (i think the flash was OFF meanwhile) and after that it worked, seems like the system needed to get some juice into it first.
i havn't had the batteries in all night, and just popped them back in now, and there was no problem/wait, so perhaps it is just a firsttime thing ?
hope this helps, i was ready to replace my unit... i dont get why the manual says nothing about this "issue" .. that was very frustrating.
Regards
Simon
New Contributor
I had the same problem. First I tried new batteries. No luck. I have two 600EX-RTs so I swapped batteries. The "Bad Batteries" workered in the other unit. The other units' batteries wouldn't work in the unit in question. I tried hitting the reset buttuns with no luck. I had had the new unit for a few month's but haden't used since I first got it. I was ready to return it. But of course I came here first. Holding down the two reset buttuns while turning the unit on is a challenge. Especially when you're ready to throw the thing down. First I tried holding the two buttons down while going from off to on and then lock. No luck. I tried it a few times. Then it tried holding the buttons down while going from off to lock then on. No luck again. Then I tried opening the battery compartement, turning the unit on and then closing the door. No luck again. I gave the first solution again, by holding the two buttons down, going from off to on then lock. Then it worked. This was at 10:00 at night and I was tired and might not have all the sequences exact, but the moral of the story is to try and try again. Hope this helps.
New Contributor
Finally got it running doing the clear screen hold/reset and then turn on method.   As you said it took more than one try - in my case seven times.   Thanks to nvs397 for pointing out that you have to do it multiple times or I would have been stuck.
Kind of a stupid thing to have to do.   Not sure why Canon cannot fix this...
New Contributor
Hi
I just unboxed my 600ex-rt and it shows the same battery symbol... I put the flash on my camera and te af assist beam actually works but the screen shows the striked out battery and the flash does not go off... I tried the on position with the battery cover and it doesn't work... Any advice??
powered by Lithium
